Building A 1293 / 1310 / 1340
#31
Posted 27 May 2008 - 10:41 PM
cheers
#32
Posted 27 May 2008 - 11:04 PM
Getting it balanced will isn't essential but it's ripe for a ship 'n penny of tar analogy. Use new big end nuts 'n bolts 'n consider fitting a centre main strap.
#33
Posted 27 May 2008 - 11:33 PM
i think i might get it done then just to settle my mind will anyone be able to do it or will i be better off sending it away to a specialist that does it everyday sort of thing
cheers
#34
Posted 27 May 2008 - 11:55 PM
#35
Posted 28 May 2008 - 12:09 AM
#36
Posted 04 June 2008 - 10:41 PM
#37
Posted 09 June 2008 - 11:46 AM
by the way, I've got a couple of spare sets of brand new Minispares Mega 73.5mm pistons, boxed, complete with pins and rings. A set's yours for £160 plus postage if you want them...
Still got these if you've changed your mind and want to build a proper motor
#38
Posted 09 June 2008 - 01:04 PM
Still managed to build a 145 bhp 1293 though
#39
Posted 14 June 2008 - 09:38 PM
What are the potential drawbacks as this will be run with a morspeed ph3 cam and ported head with pressed steel rockers.
Comments please
Edited by Wilson1275, 14 June 2008 - 09:38 PM.
#40
Posted 15 June 2008 - 01:17 AM
I had this problem, and went for 1293 due to being a little bit stronger and a wider variety of +20 thou pistons being available for the low compression I wanted.
Still managed to build a 145 bhp 1293 though(4 and a half grand later that is...)
What have you done to it to make that sort of power?? Full on miglia spec by the sound of it.
#41
Posted 15 June 2008 - 09:50 AM
im still with the 1330 ftw!! also the pistons i will be getting are 50 each on minispares there mega comp ones will do the trick i hope!!
cheers
#42
Posted 15 June 2008 - 02:28 PM
1310 = sacrificing capacity for quality build
OR
1330 = sacrificing small bit of quality for capacity??
the reason i ask is that these pistons are half the price of +60's (but they are out of stock atm
help please!
Edited by Wilson1275, 15 June 2008 - 02:28 PM.
#43
Posted 15 June 2008 - 04:52 PM
#44
Posted 15 June 2008 - 07:34 PM
Pretty much miglia spec and then a supercharger as wellI had this problem, and went for 1293 due to being a little bit stronger and a wider variety of +20 thou pistons being available for the low compression I wanted.
#45
Posted 15 June 2008 - 10:17 PM
get 21253 pistons as they are good 21251 are for a real budget build
for the price of those boo i could go 1330 :s
now im really confused about what to do, are the 21251's going to fail easily? the car is a weekend toy, driven hard but not abused and am trying to build a new engine on a budget but don't want to use carp parts so was trying to go smaller bore and better quality.
crikey this is complicated!!
