Spotlamps
7 replies to this topic
#1 themanlegend
themanlegend
  • 244 posts
Posted 26 May 2005 - 09:02 AM
Hello!
I have purchased and fitted with help, a set of four halogen spots, as pictured... but thats as far as I have got.
I have some idea that I need a relay and a switch in the interior so I can turn them on, thinking of a 3 way, off, on on switch so I can have two on as driving lamps BUT...
What relay would I need and what connects to the prongs that come off that relay, e.g. do I need to go to the battery or coil with one prong? really have no idea, any help greatly appreciated!
TML
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 May 2005 - 09:31 AM
if they are spot lamps they can only come on with high beam
there are 4 pins on the bottom of the relay sorry i dont know there markings
1 will be earth easy one just find a screw in the the body and put the wire under it
then one will go to the spot lights through a switch if you want to be able to turn them off
then you need to take a wire from a another pin to the head lamp main beem wire( someone on here will tell you what collour it will be )
and the last pin will be the live feed take this from where all the brown wires go near the starter motor and go through a fuse
4x50 watt spot lamps will take 17 amps so make sure fuse and cable match
#3 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 26 May 2005 - 01:00 PM
I think halfords do a kit about £10 :erm: . Should be able to sort it out with one of those.
#4 binge
binge
  • 2,508 posts
Posted 26 May 2005 - 01:10 PM
Just wire it up to a seperate switch, No need to have them wired to your high beam.
You will need a relay and set it up like so...
Good luck...
<|Ben|>
#5 themanlegend
themanlegend
  • 244 posts
Posted 27 May 2005 - 09:58 PM
woah, thats great, really helps :grin: thanks
#6 rumo
rumo
    Starting My Mini Up
  • 1 posts
Posted 03 June 2005 - 09:41 AM
Hi,
I am planning to install 4 front spots/fog and at the same time install overriders and corner bars. Is there ant problem with this combination?
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 June 2005 - 11:28 AM
Spots will normally fit in between the overriders..
On the subject of Spots/Front Fogs wiring.
The spots can ONLY come on with the Main Beam ( and should be wired as such ) also it is also preferable to have them on a switchable independant circuit as above.
Front Fog lights can only come on with the lights, and MUST switchable and have a tell-tale ( illuminated switch or light ) in the cabin.
This is UK lighting regulations, for Norway I suspect there will be something similar.
There is a thread in the tech section which has the wiring, which I will now go and find, and will edit this post when located.
#8 ]GoD[Zander
]GoD[Zander
  • 464 posts
  • Local Club: N/A
Posted 03 June 2005 - 04:40 PM
where did you get those spots from they are really nice good luck with the wiring
