Mini Minus
37 replies to this topic
#16 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 May 2005 - 02:50 PM
I think Scurvey_Dog is the man to talk to if you want a shell.... :wink:
#17 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 May 2005 - 12:45 AM
Didn't really know where to post this but does anyone know if you can convert a regular mini shell into one that looks like the minus shell?
All you need to do is deseam it isn't it??
Someone help because I'm a bit confused.. ;) :P
I have the plans to make a mini sprint shell!
#18 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 May 2005 - 12:47 AM
no a minus has the metal cut from the body and not the roof
a minus is realy a copy of a speedwell sprint that was made in the 60s
was certainly not a copy.
totally different.
mo metal minus ever produced. well only one which was used to make a mould for the fibre ones
#19 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 May 2005 - 12:50 AM
a minus shell as parts cut out of the window posts aka the roof is lower. by about 6" i think. it can be done and u can buy steel shells like this too.
a minus has nothing cut out of the window posts, only the body
the sprint shells had window posts cut down and a less radical amount in the body
#20 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 May 2005 - 12:53 AM
not a lot of people know this, but some minus shells were produced to house a mid range a-series wuth rear wheel drive.
#21 SCURVY DOG
SCURVY DOG
  • 617 posts
Posted 28 May 2005 - 10:40 AM
yes i will br producing a minus shell but with a few small changes
will let everyone know when its ready
#22 ryan69
ryan69
  • 859 posts
Posted 28 May 2005 - 11:15 AM
what will the changes be?? how much?
#23 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 May 2005 - 11:20 AM
yeah, what changes?
#24 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 29 May 2005 - 08:39 PM
Can you slap a Clubman front on a minus shell. I'd be in heaven if you could!!
#25 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 29 May 2005 - 11:47 PM
yep but you'd have to cut down the clubby front, in steel first, then make a fibre front. Many kit car manufacturers would have a go i'm sure.
these guys do a normal sized fibre clubby i think
www.framini.co.uk
#26 ryan69
ryan69
  • 859 posts
Posted 30 May 2005 - 10:29 AM
Anyone know how much it would cost to deseam a mini - keeping the bumpers?
Kinda like Alex1380's
#27 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 30 May 2005 - 11:38 AM
mines de-seamed, along with flappyplasticbits's mini
mine:
#28 Madmax
Madmax
  • 2,638 posts
Posted 30 May 2005 - 11:47 AM
de-seaming costs alot due to the amount of work hours needed in doing it, most people just do it themselves and use it as a learning experience
if you get it done properly with lead instead of filler over the welded seams it can easily run into £0000's, it has to be done 6inches at a time you see
flappys mini, crud pic due to cameraphone
#29 ryan69
ryan69
  • 859 posts
Posted 30 May 2005 - 12:34 PM
Did you do yours yourself? Does it come out ok?
#30 Madmax
Madmax
  • 2,638 posts
Posted 30 May 2005 - 12:42 PM
nah i didnt do it myself, i bought the car off ebay a couple of months back for just under £400 for a rolling shell, i got a bit of a bargain
