what sort of filler could you use to smooth a bootlid? Would you use normal filler or would you use fibreglass stuff?
Smooth bootlid
Will
, May 27 2005 09:34 PM
8 replies to this topic
Posted 27 May 2005 - 09:34 PM
Posted 27 May 2005 - 10:06 PM
think it would be best to cut the dent out then weld in a flat plate and then smooth over with a small amount of filler .
if you just fill it with filler it will crack and fall out
Posted 27 May 2005 - 10:07 PM
but if you can't weld, would it be cheaper just to buy a fibregalss smooth skin ?
Posted 27 May 2005 - 10:18 PM
maybe not cheaper but it would look and last a lot better.
Posted 28 May 2005 - 09:37 AM
Smoothy Skin £30, Smoothy Bootlid £55 (with choice of two different inners).
Have seen bootlids at a show going for £90! :saywhat:
Posted 28 May 2005 - 09:35 PM
Can you pay a little extra with all the holes drilled??
Posted 29 May 2005 - 08:19 AM
Ryan,
Smudgers are very good quality, and the holes for the hinges are already indented so you just drill through them! Have to mark/drill the holes for the lock but thats not hard! Dom
Posted 29 May 2005 - 10:33 AM
OK thanks.
Posted 02 June 2005 - 11:16 AM
On all things GRP etc just take your time trimming, cutting and drilling.
You will find the Bootlids (Double skin) are quite thick, well Mini are anyway :grin: & will need rubbing down for a perfect fit. Its a time thing!
I will be at some shows this year so just come track me down for a chat/look.
