The large bearing puller from halfords has 3 legs.... and a center screw ... if you wnagle the legs around the cast hub and put the screw in the center of the drive shaft you can pust the shaft off the hub and bearings..... then you have a hub with bearings in in your hand.... to get the bearings out their is a kind of slot in the hub so you can drift the bearing cages out... i didnt take ipcs.... but its only a little fiddle to get the legs round the hub as they dont quite line up with anythin flat
Rob
ok, cheers rob. ill have a look at it tomorrow morning. i dont mind doing the bearings, as long as its off is the main thing.
thanks again.
