Ok ive done a little search on here, and looked through my haynes manual but cant find any pictures of description of the oil breather system. Where is it and what does it look like? :ermm
Oil Leak!
MiNi2iNFiNiTi
, Jun 05 2008 11:38 AM
17 replies to this topic
#16
Posted 07 June 2008 - 03:43 PM
#17
Posted 07 June 2008 - 04:50 PM
I can't for the life of me find anything on here, google or my haynes book that can help me find the oil breather. Where is it?
My engine :
[attachment=60199:engine.jpg]
My engine :
#18
Posted 07 June 2008 - 07:24 PM
The line that is laying between the Thermostat housing and your Rocker Cover and leads back to the Carb, the breather canister will be at the other end. Check that the hose is not clogged as well. Easy to check, pull the hose off the carb and run the motor.......... see if how much air is being pumped out the hose. You could always cap the carb port off with a vacuum cap and place the hose end into a plastic water bottle to see how much oil is being pumped out of the sump through the breather line............ this can sometimes be a good indication of ring condition.
Terry
Terry
