Oil Cooler Position
Posted 09 June 2008 - 09:18 PM
cheers
eddie
Posted 13 June 2008 - 10:06 PM
eddie
Posted 14 June 2008 - 07:54 AM
Posted 14 June 2008 - 10:17 PM
It has been done. I think the zcars racer has the cooler at the front. TTS do a high volume pump but I don't know if it would be required, or if the standard one is up for the job.
thanks for that koss i should ask chris he will probably know
Eddie
Posted 16 June 2008 - 08:44 AM
spoonz
Posted 16 June 2008 - 02:41 PM
anyone know the standard oil temp for the bike engine (im running a GSXR 1000) and im gettin around 140 to 150c at most., is this high ? i cant find anything on temps anywhere!!!
spoonz
To be honest, i don't really know much about bike engines but that does sound really high. Is that definitely degrees c?
Posted 17 June 2008 - 07:59 AM
Posted 17 June 2008 - 03:58 PM
what has this got to do with the position of my oil cooler?I was panicing when mine got as high as 120 degrees c so I be carefull. Are you sure your sensors are set correctly.?
Posted 08 November 2009 - 12:06 AM
Posted 08 November 2009 - 11:53 AM
What did you wind up doing? With your original question. Can the STD busa oil pump do an oil cooler mounted in front of the car.
yeh i fitted it at the front of the car on top of the subframe bar between the grille and the rad and all is fine, make sure that the correct hose is used and its a better job to get the ends crimped on by pirtek, to ensure the pipes dont blow off
Regards,
Ed
Posted 09 November 2009 - 02:03 AM
Regards,
Ed
Sweet Im going to try the same thing
Cheers,
Jeff
