Quick Shift!
Posted 10 June 2008 - 12:56 PM
i was wondering what type to get i know there is 2 but i aint a clue what they mean road?? or remote??
also i will be getting my new engine next month 1275 with the gear box was just wondering if the shifter would fit in that aswell??
cheers
Posted 10 June 2008 - 12:58 PM
cheers!!
Posted 10 June 2008 - 01:01 PM
Posted 10 June 2008 - 01:20 PM
Posted 10 June 2008 - 01:54 PM
you will need the rod type like above said
Posted 10 June 2008 - 09:50 PM
when i come to get one i will ring the company i get it from and ask them but i wont bother for the 998 just get it when i get the 1275 built up
cheers
Posted 10 June 2008 - 10:09 PM
All I would say is, make sure the gearbox is in good condition before you fit one otherwise you'll be cursing ever spending the money on one.. and remember it does not make gear changes quicker, just shorter in the throw of the gear stick, beat the clutch and you'll break your gearbox, eventually.
The best ones come with KAD written on them..
Posted 10 June 2008 - 10:31 PM
when rebuilding the gear box i will be going for straight cut gears will that be a problem?? also i thought the idea of a wuick shift was to make the distance shorter meaning you get into gear alot faster lol
cheers
Posted 10 June 2008 - 10:39 PM
Having straight cut gears won't make any diffrence, It really should be called a short shift
Posted 10 June 2008 - 11:22 PM
Ditto about the KAD, tis the only one to go for
Edited by john1.2pearl, 10 June 2008 - 11:23 PM.
Posted 11 June 2008 - 12:08 AM
Let your gearbox synchro at its own pace and don't try to 'quick' shift with these as already mentioned above, you will either lead to premature wear of baulk rings or get it wrong with the clutch.
Posted 12 June 2008 - 10:52 PM
Posted 13 June 2008 - 09:34 AM
Posted 15 January 2021 - 02:20 PM
I know this topic is ancient but my advice to everyone is - DON`T BOTHER! I put £42 worth on mine and could only get 3rd and 4th gears. No amount of messing around would get me the other gears and after weeks of messing around I`m going back to standard.
Posted 15 January 2021 - 02:37 PM
£95 plus post direct from KAD ,
Straight in,all good 🚘👍
