Bonnet Pins - Are They An Mot Failure?
Posted 10 June 2008 - 05:06 PM
Ive just got a fibreglass bonnet that i want to be secured to my car with bonnet pins (one in each corner of the bonnet).
The guy at the bodyshop has told me these could be seen as an MOT failure. Is this true?..
...Basically I need to find another solution if these pins are illegal.
Thanks for your help.
neil
Posted 10 June 2008 - 05:07 PM
Rhys
Posted 10 June 2008 - 05:10 PM
Posted 10 June 2008 - 05:41 PM
Posted 10 June 2008 - 05:47 PM
Edited by the.stroker, 10 June 2008 - 05:47 PM.
Posted 10 June 2008 - 06:16 PM
Posted 10 June 2008 - 06:20 PM
Posted 10 June 2008 - 06:27 PM
Posted 10 June 2008 - 06:30 PM
Posted 10 June 2008 - 06:33 PM
in a crash.....
Posted 10 June 2008 - 06:34 PM
Posted 10 June 2008 - 08:34 PM
Sorry to repeat this question again.
To be fair, i could always leave my original hinges and just put my normal catch steel bonnet on i guess. Just didnt fancy hitting someone and tearing their arm or leg on one of my bonnet pins!!!!
I dont want a flip front or anything, just 4 pins, one in each corner of the bonnet.
Posted 10 June 2008 - 09:02 PM
thanks for that, guess i will go ahead then.
Posted 10 June 2008 - 09:46 PM
i dont really see why brace bars are needed.... not asif an inchor so of box section will make alot of differance
in a crash.....
Brace bars are required because you have remove the inner wing... This panel forms a structurally rigid section with the wing and valance, remove the inner wing and this no longer exists and is unable to restrict the movement of the front subframe.. hence the need for brace bars...
It's got nothing to do with crash impact.
Edited by GuessWorks.co.uk, 10 June 2008 - 09:47 PM.
Posted 14 June 2008 - 02:10 AM
(this is straight from the mot testers mouth, he did query for me with vosa this afternoon )
bonnet pins WILL NOT FAIL if the bonnet, flip front or whatever is secure. the bonnet is classed as a panel therefore all panels must be secure.
its not the pins that fail anyhow its the security of the fixture.
all 3 minis we have do have pins.
my manfred has 8 pins.
if your bonnet catch is faulty it will fail, if your pins are ill fitting and cause movement they will fail. no where on a failure sheet does it list, ' bonnet pins' as an actual part of the mot test
hope this is clear. KC
Sorry to bring this up again. Im looking to fit bonnet pins during my restoration but planned to remove the bonnet catch when doing this. The car will be garraged all the time so security is not an issue.
'imabitnaughtyxx' mentions above )in red) the bonnet catch cant be faulty, I asume this means it cant be removed. Dose this relate to having pins fitted aswell? surely there is no need for pins and a latch?
While i am here can anyone recoment a good set of pins? I have seen so many on ebay but you can never be quite sure about the quality really.
