Split Webers
26 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 01:11 PM
Ok, I now have two 45's ready to build a split weber system for my next engine...
Who's done, got, running splits...?
need pics so I can have a look see...
Will probably be making my own custom manifold so what lengths have you used.
#2 thompy.mark
thompy.mark
  • 13 posts
  • Local Club: Christchurch Mini Club
Posted 18 June 2008 - 01:23 PM
See if you can get your hands on a copy of David Vizard's 'How to Modify Your Mini', it has reasonably detailed instructions with some helpful pics.
Good luck :crazy:
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 01:29 PM
that'll be the big yellow book my keyboard sits on :crazy:
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 18 June 2008 - 01:31 PM
Split 45s ! That must be some juice hungry engine you're planning :crazy:
Manifolds should be easy enough although I'm sure Maniflow produce somthing suitable - at the end of the day its only two tubes with flanges on each end!
#5 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 18 June 2008 - 01:33 PM
i have got a pic of one of my old Mini's with Split 45's but i's the only pic i can find at the mo..
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 01:37 PM
Exactly, which is why I thought I'd build my own, no need to pay Maniflow prices for basically two steel tubes with flanges on the end...
Yes I suspect I'll be doing my bit for a fuel shortage, but with a hopeful red line of 8.5-9k going to need something which can shovel the fuel in by the bucket load... and I don't do injection...
#7 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 18 June 2008 - 01:39 PM
You should speak to Nick Swift at swiftune, he recons that a single 48 is better than split 45's and it probably a damm site cheaper...
#8 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 18 June 2008 - 01:41 PM
pardon me for thinking
but surely, you are using one side of each carb? so is it not better to use both sides of one bigger carb?
and my god what are you doing to want that kind of set up!?
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 01:44 PM
The other thought was to run an IDA, but that sticking out the top of my 'supposedly' stock looking van may have been a bt of a giveaway...
#10 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 18 June 2008 - 01:46 PM
hmmm IDA any day, if i hadn't sold my old mini i would have eventually got an IDA for it...
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 01:47 PM
Technically there's little difference over running just a single 45, but it's the air flow which is changed, basically the venturi of the carb lines up directly with the port on the head, and does not have the little 'kink' in the inlet manifold... also means you can run a shorter inlet manifold therefore not requiring such a deep box.
#12 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 18 June 2008 - 01:52 PM
thanks for that gw :cry:
i always wondered, i thought it was due to pub bragging rights :crazy:
or because the works had them
#13 GraemeC
GraemeC
  • 7,440 posts
Posted 18 June 2008 - 02:05 PM
IIRC they originally came about from works set ups as they weren't allowed to use twin choke carbs but at the time the Webers were their weapon of choice - answer convert the Webers to single choke and use two!
The straight line flow is a marginal improvement over a std Weber but wether it is enough to warrant the work and cost is a different matter.
#14 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 18 June 2008 - 02:10 PM
yeah thats what i thought, i just couldnt remember properly and didnt want to seem a fool again
gw, i may have a pic on my phone of a couple, i will have a look later for you.
#15 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 18 June 2008 - 02:25 PM
Split 45's are proper thirsty!!
The length of the inlet manifold should be selected for top end or bottom end power/torque or a mixture/compromise for both.
Drag strip or road use?
