Cam Timing On A 296 Cam
15 replies to this topic
#1 imabitnaughtyxx
imabitnaughtyxx
  • 4,619 posts
Posted 18 June 2008 - 07:30 PM
does anyone know the cam setting for a kent 296 cam?
we are fitting a minispares duplex adjustable timing kit and are a bit stuck!
looked on kent website but cant find anything 296 specific
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 18 June 2008 - 07:46 PM
All Kent cams are 106 degrees BTDC. If you are using a new chain, time it to 104 degrees as the chain will stretch by 2 degrees. Some people may come on here and say they stretch 3 degrees, but Ive timed in many cams and 104 BTDC will be spot on.
Paul
#3 Sam Walters
Sam Walters
  • 2,765 posts
Posted 18 June 2008 - 08:08 PM
paul wiginton is about right there. ill be timeing mine in at that.
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 18 June 2008 - 08:10 PM
Just a note, if you like the 296, you will love the 310. I wouldnt have anything less
Paul
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 08:17 PM
If you can get one, go for a kent silent (high velocity) chain.... No stretch at all....
and Paul, yes my next cam will be a 310, having run the 296scatter for 3 years and enjoyed every minute of it...
Edited by GuessWorks.co.uk, 18 June 2008 - 08:19 PM.
#6 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Have you got the ultimate engien builder dvd? If so it goes through everything you need to do on there...
#7 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 18 June 2008 - 08:24 PM
Ive not heard of that chain, where do you get it. I use chains from Swiftune, not sure who's he supplies - probably Kent, but if thats the one Nick uses then usually thats the best. I like the idea of no stretch, means I can nail it sooner after rebuild
Paul
#8 Sam Walters
Sam Walters
  • 2,765 posts
Posted 18 June 2008 - 08:39 PM
paul what kind of power firgures are you getting with the 310? obviosly it all depends of other aspects but if your running a 310 degree cam youll most likely be running the rest of the engine on par.
thanks
Sam.
#9 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 18 June 2008 - 08:47 PM
It shows 155 at Baldwins and yes it has the best money can buy of everything.
Paul
#10 Sam Walters
Sam Walters
  • 2,765 posts
Posted 18 June 2008 - 09:15 PM
baldwinds though.
im assumeing steel crank, rods and forged pistons?
#11 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 18 June 2008 - 09:30 PM
Would this be visable for every cam? I'm putting a SW5 in soon, I know it should be 108 degree's, So should I be timing it to around 106?
Cheers.
(Sorry for stealing your thread KC)
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 10:08 PM
The reason I say 'if you can get one' is I'm not sure Kent actually make them anymore... It's a high velocity chain so is not the same construction as the 'bike like' chain as used in the duplex but is a multi link.... off to find pictures...
and believe it or not I found the pics in imabitnaughtyxx's wanted post... :)
http://www.theminifo...mp;#entry929392
I believe Min-its may still have some..
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 June 2008 - 10:37 PM
yup, nothing wrong with vernier duplex, but as said above... they do stretch
#14 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 19 June 2008 - 06:21 AM
and believe it or not I found the pics in imabitnaughtyxx's wanted post... :D
Ah, yes I remember those. Ive never run one but Swifty reckons they eat the bottom sprocket as its such a tight turn and there are so many links on the chain. I guess it depends how much grief you give it though. Constantly revving to 9,000-9,500 as I do might be what he is talking about
Paul
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 June 2008 - 06:51 AM
maybe, dunno, but mines done probably the best part of 40k now and again will take photies when I pull the engine...
surprised you've not tried the 'direct' gear driven alternative.
