Didn't know where to post this, so its here.
When i finally get my arches sorted with wood and pickett i need to paint them. So i just wondered if anyone knows if i need any special primer to paint the arches before i spray the top coat on them?
Paint
RacingGreen
, Jun 07 2005 06:37 PM
8 replies to this topic
Posted 07 June 2005 - 06:37 PM
Posted 08 June 2005 - 07:54 PM
I'm pretty sure you can use regular primer or acid etch primer (name?) but don't quote me on that..
Posted 08 June 2005 - 10:10 PM
thanks for that, hopefully i will get around 2 needing to buy the paint if wood and pickett ever get back 2 me.
Does anyone know where i could find out for sure which is the best paint to use? Not that i dont believe ryan, just want to find the best one.
Posted 09 June 2005 - 08:05 AM
Yeh normal primer is usually Ok but etch can be used because the surface of cheap arches isnt usually great. With W&P normal primer should be fine, if you want to be sure then use a light spray of etch first, then normal primer! Dom
Posted 09 June 2005 - 06:12 PM
Thanks, thats a great help. I just hope i can get the arches sorted out pretty quick now.
Posted 14 June 2005 - 03:01 PM
I'm about to get some fibreglass arches so let me know how it goes!
Posted 16 June 2005 - 09:39 PM
normal primer will do fine, i used it on mine and mine are groovey! :grin:
Posted 17 June 2005 - 12:26 AM
Yep. Just normal primer from halfords. They do sell "plastic" primer, but it dosent really matter...
IF they are plastic arches, do they have a grainy effect to them. If so, then go with "Filler primer". That will get you a smoother finish.
<|Ben|>
<|Ben|>
Posted 17 June 2005 - 08:04 AM
give them a dam good rub down to, so they go dull, take the shine totaly of them.
