ive got a 90amphour battery and a 50amp battery and a 70amp alternater, is there a way of having both charging at the same time as with it being a show car i cant afford to not have enough power for the amps but then like you say i need to be able to start it!
Firstly, starting issue.. This is why i suggest 2 volt metres. If your main 'starting' battery seems a bit low, before you turn your engine off, turn your sterio off and let her charge up a bit. Secondly, your audio is sucking up loads of juice, so the volt metre on the 'audio' battery will let you know if your eating through the full battery.
As it stands now, you watch the power cap figures, whats it start at when audio isn't on, then what figure does it drop to under full crank?
As for your betteries, Defo need bigger and deep cycle. The battery i mentioned before is Yellow top battery, click me
If your wanting more from your system, don't skimp on the important bits.
