Hi
Went for a test drive in another MPi last night, knowing that there was something wrong with it. I was told that it was gutless on hills and wouldn't rev properly over 2000ish. My first guess before I saw it was that there was something wrong with the stepper motor, but after seeing it, I don't think so anymore. It pulls OK in first and second, but third and fourth are completey dead. There's also a loud sucking of air noise (like when you run it without a filter). Unfortunately my time was very limited and I couldn't do an extensive test drive, or spend long under the bonnet.
When a searched last night the posts that were returned all relate to kanckered vacuum hoses. But the MPi doesn't have one, does it?
I've got a spare engine which I think works OK, so I can nick bits off it for testing purposes.
Where would the sucking noise be coming from? All I can think of is cracked TB. Although I didn't check to see if there actually was an air filter in the housing
Any suggestions anyone?
Cheers!
Pants Acceleration!
minicooper1.3i
, Jul 09 2008 07:29 AM
3 replies to this topic
Posted 09 July 2008 - 07:29 AM
Posted 09 July 2008 - 09:00 AM
there should be a vaccum hose going to the brake servo, is that what the other posts related to ?
definatly sound inlet / vaccum related
Posted 09 July 2008 - 09:25 AM
I had thought of that one, but I thought it was only to do with the brake servo. Does it have anything to do with the engine performance as well?there should be a vaccum hose going to the brake servo, is that what the other posts related to ?
If it was holed, would it draw extra air straight into the inlet manifold, bypassing the filter?
Cheers!
Edited by minicooper1.3i, 09 July 2008 - 09:26 AM.
Posted 12 July 2008 - 10:28 PM
Cheers!
yep, if the servo hose was holed it could draw extra air in bypassing the filter and carb. also would have a bad effect on you brake performance
Edited by v8mini, 12 July 2008 - 10:28 PM.
