Wet Feet!
Posted 12 July 2008 - 06:36 PM
Is There Any Other Way Of Telling How The Water Is Getting In??
Ive Used The Stupid Search And It Some How Manages To Come Up With The "Hot Girls In Minis" Thread!!
Cheers Guys:D
Posted 12 July 2008 - 06:51 PM
Other than that lift the carpets, dry it all out, put some talc down and then get someone to run a hose all over the car whilst you look to see where it's running in from on the inside.
Posted 12 July 2008 - 08:01 PM
And Thanks For The Reply Though:D
Posted 12 July 2008 - 08:38 PM
You might find that the body work is rusty if so you can carry on but.. also you might find taking the brown sometimes called chrome filler strip out will help.
Posted 12 July 2008 - 08:39 PM
horrible feeling having a puddle under the carpet
good luck in solvin it
Posted 12 July 2008 - 08:51 PM
Posted 13 July 2008 - 12:42 PM
Posted 13 July 2008 - 12:45 PM
Looks Great!! Probs Wont Get Around To Doing Anything TodayI've heard good things said about this stuff: -
http://www.frost.co....o...=&subCatID=
Cheers For The Link By The Way!
Posted 13 July 2008 - 12:58 PM
Might just phone up the local glass people and have them put new front and back windscreen seals in as the back window seal is missing an inch of rubber so the water has been pouring in through there!!!
Posted 13 July 2008 - 01:39 PM
Posted 13 July 2008 - 02:05 PM
Posted 13 July 2008 - 04:34 PM
To Solve This Just Buy New Door Seals?? No Way Or Unsquashing Them ThenCheck your door seals too, they usually get squashed up where the door check strap is, and can split, thus letting water in, which can the run down the door into the footwell.
Posted 13 July 2008 - 05:31 PM
I need the door seals changed on my work van, if it's been raining heavy, or if i drive through huge puddles after it's been raining, (which i do quite a bit!) the passenger footwell is wet, luckily my van has rubber flooring so i can easily mop it up.
I think off hand the seals are about £11 each from minispares.
Whilst you're checking the seals, see if the seal round the check strap itself is intact, they seem to just disintergrate after a while. Again, i don't they they're that much.
Posted 13 July 2008 - 07:38 PM
One way of telling is to make sure all the trouble spots (windscreen, doors etc) are dry then put talcum powder around them on the inside, shut everything up and spray a hose at the car - the talcum powder will run where the water has come in
If there aren't already, you could drill some small drain holes in the floorpans to let the water drain too, not ideal but a fine short-term bodge until you can sort the leak out
Posted 13 July 2008 - 07:46 PM
I Shall Order Some New Seals ASAP And When The Car Shop In Good Ol' Chard Opens Ill Get Some Sealant!
I Don't Think Ill Result To Drilling Holes Yet
Thanks Again
