Wet Feet!
29 replies to this topic
#16 minili
minili
    Awesome and Flattering
  • 5,140 posts
Posted 13 July 2008 - 07:54 PM
Many Minis already have drain holes drilled in the footwells which is why I mentioned it :thumbsup:
Good luck anyways :D
#17 captainjack15
captainjack15
  • 3,925 posts
Posted 13 July 2008 - 08:19 PM
Cheers :D I Dont Want To Be Drilling Unnecessary Holes Though!!
Would Someone Be Able To Make A List Of Seals I'd Need For My 2 Doors Please? Im Confused As There Are Soooo Many On Minispares and Minisport!
If It Helps I've Got A 1990 Racing Green.
:proud:
Thanks :D
#18 M44K TS
M44K TS
  • 3,104 posts
Posted 13 July 2008 - 09:01 PM
For the door surrounds
http://www.minispare....aspx?pid=36978
For the check strap if they're shot.
http://www.minispare....aspx?pid=38146
#19 captainjack15
captainjack15
  • 3,925 posts
Posted 13 July 2008 - 09:06 PM
Thankyou Very Much!! Really Handy! :proud:
#20 captainjack15
captainjack15
  • 3,925 posts
Posted 14 July 2008 - 06:18 PM
I Was Just Wandering Is There Any Way I Could Replace Seal On The Sun Light Thing? I Cant Find It On Minisport? Thanks ;)
O And What Is A Check Strap :S:P
#21 captainjack15
captainjack15
  • 3,925 posts
Posted 14 July 2008 - 07:31 PM
*Ahem* ;)
#22 M44K TS
M44K TS
  • 3,104 posts
Posted 14 July 2008 - 07:54 PM
check strap is the small bar that stops the door opening too far, it's on the hinge side of the door near the top. There should be a sort of flat rubber seal that goes around it.
By 'sun light thing' do you mean your sunroof?
#23 captainjack15
captainjack15
  • 3,925 posts
Posted 14 July 2008 - 08:11 PM
Yeah But Its A Sun Light Because It Doesnt Open, But Yeah ;)
And Cheers For Replying I Found Out Shortly After I Typed It :D
#24 captainjack15
captainjack15
  • 3,925 posts
Posted 15 July 2008 - 07:54 PM
Someone Must Know ??????
Please, Help A Poor Mini Owner Out :lol:
#25 captainjack15
captainjack15
  • 3,925 posts
Posted 16 July 2008 - 08:10 PM
A Little Update For You Lot :lol:
Well I Dried It All Out Put Sealant Around The Windscreen, Then Let It Set And Got My Mums Partner To Spray Water All Over The Car And I Noticed A Little Tricle Of Water Coming Out From Under The Door, Then Another. So I Assume Its Coming Down One Side Of The Window Then Getting To The Bottom, And Working Its Way Into My Nice Dry Car!!!! While I Was Out There I Could See That There Was A Gap In The Seal Because The Wing Mirror Is Pulling It Away.
Can I Solve This Any Way Possible? And Its Already Got A Drain Hole In The Door!
Thanks For Help So Far :P
#26 captainjack15
captainjack15
  • 3,925 posts
Posted 18 July 2008 - 01:28 PM
Being Ignored Sucks? Come On I Really Need Help, What Can I Do!?!
#27 miniEgg
miniEgg
  • 766 posts
  • Local Club: westcountryminis
Posted 18 July 2008 - 02:15 PM
if the water is running down the window and in, take the door card off. and tape up all the holes on the door. use duck tape or something, we were getting water in and it was running into the door and splashing through the middle hole of the door. have seeled them all up and now have a nice dry mini >_<
most of us lot are at work between 9 - 5 :dontgetit: so cant respond instantly, not ignoring, just busy mate :P
#28 captainjack15
captainjack15
  • 3,925 posts
Posted 18 July 2008 - 02:18 PM
Awesome, Ill Get That Sorted Asap!!
You Say That But No One Works 6 Days On The Trot >_<
#29 miniEgg
miniEgg
  • 766 posts
Posted 18 July 2008 - 02:20 PM
well it is friday >_< a normal working day. i used to do 7 days
#30 jordie 08
jordie 08
  • 489 posts
  • Local Club: no club
Posted 18 July 2008 - 02:23 PM
some silicone around the bulkhead holes
