Tore The Rear Suspension Mounts Off The Tubeframe !$@#?
Posted 17 July 2008 - 02:42 AM
This is the left rear shockmount, all I noticed was the rear of the car was getting lower and lower untill the rear wheel arch started smoking off the tire:
The right side is on its way out too:
Adam.
Montreal, Canada.
Posted 17 July 2008 - 09:52 AM
Has this happend to anyone yet? I know the roads arn't perfect here but I wasn't expecting this. This is a point that should not be overlooked.
Adam.
Montreal, Canada.
Interesting that the tube has torn not the weld cracked.
Best call Chris direct if you have not done so already. Normally Chris over engineers his constructions and haven't heard of failures.
David
Posted 28 July 2008 - 07:09 AM
I would hate to live in your street..........
with all the pot holes and smoke from your tyres rubbing.......
Hope you get back on the road asap....
Posted 14 August 2008 - 06:11 PM
what they gonna do, im really interested
Edited by Spoonz, 14 August 2008 - 06:11 PM.
Posted 14 August 2008 - 06:43 PM
what happend about this ?
I've since chaged the design / location of the shock mounting location.
I don't expect Zcars to do anything about it since they haven't even returned my emails about my sprocket and or drivshafts that were supposed to be shiped to me in May!!!
Another note, don't go for the LSD option in the bike kit. It's pure junk. The Quaife version is only a few $100 more and it works unlike the used / wornout ford parts on my car. Too bad im from the other side of the ocean, because I would of showed up on Zcars front door step a long time ago.
Posted 14 August 2008 - 06:56 PM
but whenever i phone them, usually with a stupid/pointless question, they're more than helpful.
Basically they've bent over backwards to help me, i'm sure yours is an isolated instance
Posted 14 August 2008 - 07:59 PM
PS I haven't bought a kit and have no connection
David
Posted 16 August 2008 - 05:02 PM
we always answer the phone and many of my customers will tell you that they have contacted me at late hours and weekends
i was even open on christmas day!!
i have no knowledge of this problem at all or anything to do with driveshafts and sprockets so if you want to get in touch then please try calling us or mailing again you can also use my cell phone on +447786 707734
i do know that our e mail is sometimes problematical but i cant do much about things disappearing in the world wide web
i have only seen this problem on one other car and it was down to a bad length of steel that we got
obviously it takes some time for this to occur and is nearly impossible to predict
we have over 300 mini kits out there with no problems of this nature but since finding the first one with bent brackets we now put a thicker tube on that point AND a bracing gusset in the plane that the stress goes to
with regards to diffs we use two diff types one for road use which is a viscous type and one for race which is a plate type
the race type will allow you to drive with a broken drive shaft on the remaining good shaft and is a very good diff far superior to the quaife which stops driving if a wheel leaves the tarmac
if you have a problem with anything we do please do call and ask for me i dont like things that are not good on the cars and will react to anything that comes up to prevent it happening again
chris allanson
Posted 16 August 2008 - 05:14 PM
just bollocked richard for not doing the shafts and sprocket on time
unfortunatly id not seen this to sort it out before hand
apologies adam
chris
Posted 19 August 2008 - 04:20 PM
Adam.
Posted 23 August 2008 - 11:19 AM
Chris is a totally stand - up guy, based on my interaction with him (even on the other side of the pond).
I'm certain he'll sort your car's issue out quickly.
