Battery Drain, Cannot Identify It!
Posted 31 July 2008 - 12:57 PM
So know I have 2 problems:
1 - Now i know which fuse it is how do I check which component is draining?
2 - From checking all the fuses I noticed that the wrong fuse was in at the top as this was only 13A and my Haynes says it should be a 35A fuse, I have since replaced and checked the rest of my fuses but could this of damaged any of the components the fuse was supposed to be protecting?
Cheers in advance for any help its greatly appreciated
Posted 31 July 2008 - 01:00 PM
Posted 31 July 2008 - 03:27 PM
Do you have an alarma and\or imobiliser fitted? These beggers do contunualy drain the battery!!!
I have a laserline alarm and immobiliser fitted but not armed, even when i unplug this there is still 0.1 amps being drained by something. Is there also a factory standard immobiliser fitted? My mini is a 1994 Mini cooper SPI
Posted 31 July 2008 - 07:02 PM
Seriously 0.2amps is F**** all
Posted 01 August 2008 - 02:38 PM
Pull the Hazard warning relay and then check battery drain
Cheers for that sprocket, where abouts is this located? I have checked behind the dash but cannot seem 2 locate it
Posted 01 August 2008 - 04:59 PM
Posted 01 August 2008 - 05:55 PM
I went through all this and eventualy found it was either the dim dip relay or the hazard relay that was causing this small drain. Cant rmember now which was which ,lol, but if you see a big orange relay up there as well, pull that, I think that is the dim dip relay.
Posted 01 August 2008 - 09:42 PM
The hazard warning relay is behind the dash in the center up by the top dash rail.
Cheers for the suggestions will give them a go and get back to you. If it is the relay do i simpl need to replace it?
Posted 02 August 2008 - 12:29 AM
