hi,
i am going to get a good (low mileage) metro 1275 engine later this year which should go into my studio2 as i need the 1000cc engine to be put into my 25 (but that's a different story)
my aim: i want a reliable touring engine for motorways and longdistance traveling...
modifications i am having in mind are as follows:
- stage 1 kit (single box centre exit rc40)
- swiftune sw5 cam
- centre oil pickup
- centre main strap (does this really make sense??)
- lightened flywheel
- 2.9 diff (which i have anyway in my 25 engine)
as mentioned i am not looking for highest output. my thoughts were: as i would like to have the 2.9 diff the lightened flywheel in combination with the wider torque range of the sw5 cam and the stage 1 should be able to cope with that... right??? will the engine be able to rev to 5500-6000 rpm?
have i forgotten something (in terms of reliability)? or am i completely wrong with what i'm thinking?
any opinions or suggestions?
thanks for every help...
1275cc
Guest_falk_*
, Jun 16 2005 10:03 PM
7 replies to this topic
#1 Guest_falk_*
Posted 16 June 2005 - 10:03 PM
Posted 16 June 2005 - 10:32 PM
you really want lots of torque and less revs. the 2.9 will b good for motorway use. Id also go for a twin back box system for sound on motor way journeys and the less low down torque thats lost. The sw5 is perfect. Its also worth havign new bearings and piston rings/hone if not rebore at the same time
Posted 16 June 2005 - 10:38 PM
i wouldnt go for a super light weight flywheel or else pulling off with a 2.9 final drive will ber rather difficult depending on the torque of the engine.
Posted 16 June 2005 - 10:56 PM
Pesonally, unless your intending on thrashing it around, I don't think the CPU or Mainstrap are worth it, unless you're planning on rebuilding the whole engine.. I ran my 1330 for 30k without a mainstrap with no issues, and
If your after any form of economy I'd be tempted to stick with a standard or slightly lightened flywheel, as this ads inertia to the rotating components, and hence makes crusing easier.
Maybe improving the head, some mild porting to improve the breathing, or an MG Metro/GT head...
#5 Guest_falk_*
Posted 16 June 2005 - 11:17 PM
lots of new input already... :grin:
thanks so far.
honing and pistonrings: is it necessary if the engine has been running only for something around 23k miles?
centre oil pickup and centre main strap: thought when the engine is open for the cam change (incl. followers etc) it would be worth doing it? but you're right i'm not going to open the engine just for these...
lightened flywheel: the biggest news to me... i thought the engine gets enough resistance from the 2.9 diff and so it would help to lighten the flywheel. but i learned my lesson now...
twin box system: definitely a no as i'm currently having a centre speedo fitted (almost no sound deadening material) and steel solid subframe mountings. so the only thing i'm hearing is the engine/carburettor... don't mind the sound though... and more important: the car sits low and we have many bad roads in leeds with lots of speedbumps that i pass everyday on my way to work... don't want them to catch my exhaust...
otherwise... this low down torque argument... is the difference really that big?
nice getting that much technical advice that quick...
thanks so far.
I've been thinking for some time that you could make a good touring engine from an A series by squaring it off. You can get it nearly square with a rebore and a destroke, and it stays almost at 1275 (can't remember how big exactly). Although it would be a very expensive way to gain no extra capacity.
Ah well there you go, just me rattling on about nothing again.
Posted 16 June 2005 - 11:28 PM
im thinking that would give you a good balance of torque(large bores) and higher rpm(destroked crank)?
Posted 17 June 2005 - 10:15 AM
No, making it square would increase power definitely, and it would rev higher (probably the reason for the power increase:p). Torque comes from longstroke cranks generally, anythything which is shortstroke/square is more RPM/hp oriented.
