How hot does your mini run
19 replies to this topic
#16 Boab
Boab
  • 1,610 posts
  • Local Club: E*S*M*O*C
Posted 20 June 2005 - 08:48 PM
Frothy radiator sounds daunting. Check that the cylinder head gasket has not failed.
#17 Mini Man Sam
Mini Man Sam
  • 158 posts
Posted 20 June 2005 - 09:57 PM
Don't think head gasket gon. No loss of compression or coolant and no white smoke/steam out back.
#18 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 20 June 2005 - 10:06 PM
Bit off topic but is water from a dehumidifier better for the radiator than tapwater?
#19 Cir-clipalot
Cir-clipalot
  • 310 posts
Posted 21 June 2005 - 05:50 PM
I'd've thought so as its basically distilled water isnt it?
#20 rob mini
rob mini
  • 1,420 posts
Posted 21 June 2005 - 07:43 PM
mine runs at the 3/4 mark. i get a bit worried when it reaches the red but it seems normal on this lump. when i had my modified head on though with a little grind where the peak comes out between the valves it never came above half, except the time it touched red when the HG went :w00t:
i dont worry about it anymore, it sits at a constant temp at 70mph so im fine with that. i dont want to break down but it is only a couple of hours work 2 do a head gasket!
