And that would make the bang sound inside the carb and cause it to smoke?
if it's sparking when the inlet valve's open, mixture will be burnt right up into the manifold and carb - smokey time!
Posted 06 August 2008 - 06:36 PM
Posted 06 August 2008 - 06:38 PM
Posted 06 August 2008 - 06:43 PM
Posted 06 August 2008 - 10:23 PM
Edited by mk1leg, 06 August 2008 - 10:25 PM.
Posted 07 August 2008 - 01:51 PM
It sounds as your timming is out....this is what you have to do .....
1.....remove rocker cover and put it in 1st gear remove spark plugs and roll forward untill nos 1-2 valves at rad end are rocking this means your on a firing stroke .............
2.......remove dizzy cap and put a dot of white paint oppisite rotor arm, replace cap andslaken dizzy clamp bolt and turn dizzy intill no 1 lead is oppisite white dot......
3.........now retighten dizzy clamp and check lead order 1-3-4-2 in anticlockwise order.....
4...........replace rocker cover and spark plugs and you should be ready to start engine this is a an approx timing as you will need to use a strobe light to set it right.................
good luck.....................
Edited by MiNi2iNFiNiTi, 07 August 2008 - 02:00 PM.
Posted 07 August 2008 - 03:53 PM
Edited by MiNi2iNFiNiTi, 07 August 2008 - 04:23 PM.
Posted 07 August 2008 - 06:11 PM
Posted 07 August 2008 - 07:37 PM
.no play in the tappets at cylinder 1 and a little play in those at cylinder 4.
Posted 07 August 2008 - 08:44 PM
Posted 07 August 2008 - 08:52 PM
The tappets should be loose on cylinder one (valves shut) if you have set them with the tappets tight (valves open) then the timing would be 180 degress out.
Paul.
Posted 07 August 2008 - 10:13 PM
Posted 07 August 2008 - 10:43 PM
Posted 07 August 2008 - 11:01 PM
Posted 07 August 2008 - 11:07 PM
Posted 07 August 2008 - 11:21 PM
