Hi everyone.
Ive had my SPI a few weeks and has been running ok'ish.
Yesterday i noticed that the stepper motor was unplugged so i have plugged it back in.
Now it is not ticking over very well and nearly stalling.
Any ideas what i can do??
Do i unplug it again or sort it?
Im in West Sussex and there seems to be a shortage of specialists here if anyoneknows any
I know o a couple on the coast but none in crawley area??
Dave
Stepper Motor?
Dave H
, Aug 07 2008 11:45 AM
3 replies to this topic
Posted 07 August 2008 - 11:45 AM
Posted 08 August 2008 - 09:58 PM
Are you sure it was the stepper motor that was unplugged? Unplug it and try it again.
When you turn on the ignition - does the stepper click a few times. then when you turn the ignition off - does it click some more?
If it does that - it wasnt the stepper motor that was unplugged.
Check the forum above for the injecton specific thread - very helpfull - helped me sort my issues out.
Posted 09 August 2008 - 12:44 PM
If the stepper has been left unplugged, I can only assume that some one in the past has thought they had a problem, and the only way they could resolve it was to un plug it. I will also assume that the throttle stop has also been adjusted, that, I am afraid, will require the use of a diagnostic service tool to set up the stepper mottor correctly.
Firstly I would check that all the small vacuum lines are connected and in good condition. There are plenty of topics around on this subject so have a search. but, when it comes to setting it up, you need the diagnostic.
Posted 26 August 2008 - 09:29 PM
where is the steper motor located?
