Rocker Cover And Hammerite
19 replies to this topic
#16 stormintrooper
stormintrooper
  • 2,072 posts
Posted 11 August 2008 - 09:58 PM
well im gonna soak it in hot water and then dry it, so will i still need the etch primer if i do that for the rocker cover,
sorry for being a pain in the backside although i dnt realy know anything about special paints and im very confused
#17 mike.
mike.
  • 6,176 posts
Posted 11 August 2008 - 10:00 PM
I think you will be best using it on the rocker cover as it is a smooth bare metal surface. You don't need on the engine block tough as you tend to paint over the old paint which is already a rough surface for the paint to grip if you like.
#18 stormintrooper
stormintrooper
  • 2,072 posts
Posted 11 August 2008 - 10:03 PM
ok thanks :yinyang:
what about ur smooth areas on the other things u painted in ur topic?
would it be a good idea to use some on those areas?
#19 mike.
mike.
  • 6,176 posts
Posted 11 August 2008 - 10:07 PM
I didn't prime anything at all in my engine bay, just used high temp paint. Other smooth things like the brake and clutch fluid reservoirs i just painted straight with hammerite. However the paint chips off very very easily which causes a chain reaction a the rest easily flakes off.
If i did it again i would key the surface with some fine sandpaper to remove the smooth glossyness of these parts to allow the paint to stick better.
#20 stormintrooper
stormintrooper
  • 2,072 posts
Posted 11 August 2008 - 10:24 PM
so i cud do that or use the etch primer?
lol
