Fitting A Badge
11 replies to this topic
#1 MiniDick
MiniDick
  • 597 posts
Posted 15 August 2008 - 06:52 AM
I've got a brand new chrome 1000 badge for my Mini. I've had it yonks and I tried to flog but no-one seemed interested so I've decided to fit it. It's the same type which was fitted to the Minor and the early coopers I think. It's got two lugs on the back so I need to drill the boot to fit it. I was thinking of putting it below the boot handle, is this the right place for it? Or does it go to the right of the rear reg plate? I'm a bit iffy about drilling the bootlid, whichwas the reason I was going to sell it but it's a nice classic looking badge. How do I get it central and whats the best way to fit the badge, any advice would be great.
#2 miniman retford
miniman retford
  • 3,553 posts
Posted 15 August 2008 - 07:46 AM
If you dont want to drill the bootlid could you not take the lugs off & use double sided sticky tape ?
Edited by miniman retford, 15 August 2008 - 12:28 PM.
#3 ash
ash
  • 152 posts
Posted 15 August 2008 - 12:03 PM
As above, but you could use some glue.
The guy who owned my mini before me stuck the badges on with No More Nails.
#4 Doodle
Doodle
  • 314 posts
Posted 15 August 2008 - 02:11 PM
theres special trim adhesive tape, i cant recall its exact name but i'm sure someone on here knows what its called, i wish the previous owner of my mini had known about it rather than deciding to use two phillips head woodscrews to secure my front badge!!
#5 MiniDick
MiniDick
  • 597 posts
Posted 15 August 2008 - 05:11 PM
I was thinking about cutting the lugs off and using that double sided trim adhesive. I thought maybe the badge would be too heavy.
#6 Ethel
  • 26,583 posts
Posted 15 August 2008 - 05:17 PM
Get some holes drilled, they'll make less mess than a badge you've had to lever off - and the badge will be reusable.
#7 Joef
Joef
  • 518 posts
Posted 16 August 2008 - 04:35 PM
Mine are all siliconed on! It sticks well once dry, is waterproof and doesn't leave a mess when it comes off! Can't go wrong really.
#8 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 16 August 2008 - 04:41 PM
If it has lugs, it's meant to be fitted through holes with special washers behind which grip it, or plastic thingies you can buy off minispares. If you don't want to drill holes, grind the lugs off and use double sided tape. Anyone who uses silicone on a car should be shot. If you've ever tried painting a car which has had silicone on it, you will know what I mean.
Edited by panelbeaterpeter, 16 August 2008 - 04:41 PM.
#9 Joef
Joef
  • 518 posts
Posted 16 August 2008 - 05:15 PM
Oops! My door seals, windscreen seal, boot seal, petrol cap, headlights, indicators and boot light are all siliconed.. Surely an electrical sander will take it off? It's being resprayed soon as well >_<
#10 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 16 August 2008 - 06:51 PM
Silicone reacts very badly with paint, creates little craters known as "fisheyes". Once it's been used, it's very difficult to get rid of all traces.
#11 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 16 August 2008 - 07:34 PM
>_<
#12 ozzie770
ozzie770
  • 43 posts
  • Local Club: n/a
Posted 17 August 2008 - 02:41 PM
If you dont want to fit it,, how much you want to sell it for..
send a pm and ill take it off you
