has anyone got a dash from 'exim trading'?
Does it actually fit?
Dash?
screech
, Jun 23 2005 04:34 PM
3 replies to this topic
Posted 23 June 2005 - 04:34 PM
Posted 23 June 2005 - 05:27 PM
yeah i got an exim dash! they do fit but you may have to make a few mods.
the fresh air vents need the solid pipe cutting of just about 1cm behind the vents and the carbord type pipe fitted instead
the big on is the problem i had. when you offer the dash up the catch for the glove box fouls the dash rail so this needs to be modified. the best way is to offer the dash up to where you want it to be and mark the area where the catch is on the top dash rail. then carefull use a hack saw to cut the area to be removed and then bend the center bit back. be carefull not to cut too far into the dash rail otherwise you will see the cuts with the dash fitted.
Posted 23 June 2005 - 08:44 PM
your car looks really nice now inside i carnt wait to see it in person i think wendys is on about coming down sometime soon
Posted 24 June 2005 - 01:47 PM
thats CF dash look really really nice!!!
