Edited by tmsmini, 22 August 2008 - 07:10 PM.
Cleaning Mpi Inlet Manifold
tmsmini
, Aug 22 2008 07:09 PM
1 reply to this topic
Posted 22 August 2008 - 07:09 PM
What should I use to clean the MPi inlet manifold and other components? I am afraid that regular carburetor spray cleaner will damage rubber O rings, gaskets and perhaps some of the sensors. I would remove everything, but I am having trouble finding O rings and gaskets on this side of the pond. I am afraid if I remove something the ring or gasket will be damaged
Posted 24 August 2008 - 08:46 PM
You should be ok with something like WD40, I always use it for cleaning up componants with no side affects to date.
