hello,
i whas thinking of installing an spi engine in hte misses her van. possible it is don't doubt about that but the thing i'm thinking about is the fuel tank ? is it just so simple to cut a hole in the tank of the van to install the fuel pump of an spi tank ?
any idea's suggestions ?
freaker
Spi Engine In Mini Van
freaker
, Aug 25 2008 11:30 AM
6 replies to this topic
Posted 25 August 2008 - 11:30 AM
Posted 25 August 2008 - 07:00 PM
Solder a return line onto the tank, or, 't' into the fuel line off the tank, for the return.
Use an external pump mounted on the subframe.
Then ther is no problem
Posted 25 August 2008 - 07:24 PM
and may i ask what fuel pump you would suggest ?
freaker
freaker
Posted 25 August 2008 - 07:36 PM
When I did this conversion in my estate I used a metro turbo fuel pump running at 1bar and it worked perfectly well. You can pick them up for about £20 brand new if you look around.
You idealy want to mount the return line as high as possible if your bringing it back to the tank.
EDIT: This is the bloke I got my pump from
Ebay Linky
Ebay Linky
Edited by Major Burkenshaw, 25 August 2008 - 07:37 PM.
Posted 25 August 2008 - 07:42 PM
Also, if your using the original 2 clock dash you'll need to solder in a diode to stop the alternator backfeeding the ignition circuit, stopping you from turning the car off caused a bit of headscratching when it first happened to me
Posted 26 August 2008 - 07:49 AM
can i ask where did you mount youre fuel return line then ?
freaker
freaker
Posted 26 August 2008 - 05:59 PM
This is looking up at the N/S of the fuel tank
Sorry for the bad pic, but you get the idea. I did find through use, that the tank could have done with some more baffels in it
Edited by Major Burkenshaw, 26 August 2008 - 06:01 PM.
