Engine Problem Strting To Drain Me, Need Help
13 replies to this topic
#1 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 07:38 PM
1275gt
year unown
cant get it to run smooth and with out back firing
road race cam, make and model unown
ok ill go over what has been tryed and tested to date.
oil pressure tested and fine
compression tested and good
timing set and advance waits checked all spot on
firing config 1342 fine
carb and manifold taken off carb cleaned and gasket replaced, all fine and no leeks
tryed almost everything but cant stop the back firing and runs lumpy, the only think i can think of is the cam and valve set up, but if any one has any other things i can check please feel free to post it up, the more help the better
thanks guys
Edited by tango'd, 25 August 2008 - 07:48 PM.
#2 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 25 August 2008 - 07:42 PM
try 1342
#3 Retro_10s
Retro_10s
    Moderator
  • 10,178 posts
Posted 25 August 2008 - 07:43 PM
firing config 1243 fine
BONG!... 1342 is the firing order, rosslin you beat me to it you banana :)
Edited by Retro_10s, 25 August 2008 - 07:44 PM.
#4 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 07:44 PM
try 1342
why is that, i was shore that the firing set up was 1243 or am i confused??
nope im confused its been a long day and i have put it down rong twice so ignore the 1243 guys im tyrd lol
Edited by tango'd, 25 August 2008 - 07:47 PM.
#5 Retro_10s
Retro_10s
    Moderator
  • 10,178 posts
Posted 25 August 2008 - 07:46 PM
You are wrong and confused :) Firing order on an A-series engine is 1342. :)
Edited by Retro_10s, 25 August 2008 - 07:47 PM.
#6 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 25 August 2008 - 07:51 PM
and i had to check to make sure even after the 1000th time! :)
was listening a bit of yello today must of rubbed of a bit :)
#7 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 07:53 PM
i no how you feel, we have been working on the car most of the day and nothing seems to have changed since we started working on it last week even tho we have tryed soooooo much and acheaved so little
#8 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 08:01 PM
bump
#9 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 25 August 2008 - 08:02 PM
so how dose a back fire come about? you have petrol in the exhaust that is firing? so is the cam timing correct? if you have lined up the dots the chances are it might not be correct? remove the rocker cover to see what the valve are doing take out the plugs and the dizzy cap line up to fire on number 1 and see what the rotor arms doing are the points open look to see if the exhaust is still open. maybe the problem will show its self.
#10 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 08:04 PM
will give that a go tomoz but as the post sez, it the one thing we havet checked so its next on the list. thanks again
#11 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 25 August 2008 - 08:06 PM
lets us know how you get on. some times it makes it all clear after a cupper or a nights sleep
#12 Retro_10s
Retro_10s
    Moderator
  • 10,178 posts
Posted 25 August 2008 - 08:18 PM
have you check the firing order then?
backfiring also often caused by under fuelling by the way...
Edited by Retro_10s, 25 August 2008 - 08:19 PM.
#13 tango'd
tango'd
  • 71 posts
Posted 25 August 2008 - 08:31 PM
when we took the carb off for cleaning there was puddles of fual sitting at the top of the inlets on the head and the carb has been striped, cleaned and rebuilt so i think fual is fine, the firing order is fine and has always been fine i just had a moment of crazyness when i 1st posted and i put it down rong
#14 mk1leg
mk1leg
  • 9,343 posts
Posted 25 August 2008 - 11:35 PM
Hi try checking dizzy leads on cap 1-3-4-2 in anticlockwise order starting with No1 @ 1o'clock.............. :D
