Bodge Job I Need To Fix
39 replies to this topic
#1 danny2009
danny2009
    Previously 'gerrard'
  • 1,069 posts
Posted 27 August 2008 - 12:00 PM
i have got to drain my oil and have obviously got to take out the sump plug, easier said than done, some one has but a square bolt where there is supposed to be a sump plug so it has been bodged how do you get it out as it is square. also i have just read something about converting a car to unleadded i have a 1986 austin mayfair do i need to do anything to my fuel or just bang unleaded in like you do to new modern cars new to all this so any help is apreciated
Edited by gerrard, 27 August 2008 - 12:01 PM.
#2 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 27 August 2008 - 12:04 PM
Are you sure its not a square headed screw in plug like
http://www.hercules-...Square_Plug.jpg
If so it should unscrew
Fit an unleaded head if you dont already have one or use a fuel additive
Edited by ratty, 27 August 2008 - 12:06 PM.
#3 Waffs1984
Waffs1984
  • 437 posts
Posted 27 August 2008 - 12:06 PM
Hi,
I think i am right in that post 1984 the majority were already unleaded? My '85 mayfair is although it is possible it was converted by a previous owner if this is not the case! I'm sure somebody will be along soon to correct me if i am wrong!!!
As for the sump plug, get it with a large spanner, it doesn't have to hexagonal to use a spanner just make sure you get the correct size for the distance between flats if that makes sence!!
Hope this helps!
Matt.
#4 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:07 PM
nope its like this but the head is a bit longer and got a C stamped in it
Attached File  VCB253.jpg   2.53K   9 downloads
#5 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:09 PM
Hi,
Hope this helps!
Matt.
tried it and tried hammering a slightly smaller spanner and socket on but no joy, i have left it to soak overnight with WD40 and just put some more on now
#6 Ethel
  • 26,156 posts
Posted 27 August 2008 - 12:10 PM
You could find anything when you tackle the sump, so think ahead about how you'll get it fixed if needs be. It could be a proper repair, you won't know until the plug is out. Sounds like it might be a sump plug off another car or even a plumbing fitting. An open ended spanner will fit if it's a square peg.
#7 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:12 PM
tried it wont budge dont know how they got it in but it is tite and also i have tried mole grips and plyers wnt budge
#8 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 27 August 2008 - 12:14 PM
Try a long handled stillsons wrench
#9 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:16 PM
havent got one of them so that will have 2 be one of the last resorts lol
#10 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 27 August 2008 - 12:20 PM
Ask a local garage to loosen it for you (helps if you have a 4 pack of beer handy ;) )
Edited by ratty, 27 August 2008 - 12:20 PM.
#11 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:21 PM
lol cars sorn its a project (ish)
#12 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:28 PM
ani more ideas i need to get it out
#13 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 27 August 2008 - 12:30 PM
Weld a large nut on top and use a big socket or borrow a wrench from a plumber
Edited by ratty, 27 August 2008 - 12:31 PM.
#14 danny2009
danny2009
  • 1,069 posts
Posted 27 August 2008 - 12:33 PM
i havent got a welder and i havent got nothing to heat ti up with nt r8 good am i i only got basic tools
#15 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 27 August 2008 - 12:37 PM
Don't remove the square head bolt until you have determined (at least in part) how you are going to handle the situation. If you damage something removing the bolt, you should be somewhat mentally prepared for how you will fix things.
HeliCoils are the standard sump drain fix. It's easier to do with the engine out, however, it can be done with the engine in place.
As for getting the square head bolt out, strike the head of the bolt like it was a nail. The goal here is to shock the joint and hopefully free the surfaces that have probably galled together. Do not count on the WD-40 or other penetrating oil to get in there. Consider what this is... it's a bolt being used as a drain plug. However it was installed, the person who did it made sure oil wouldn't leak out around it... so your WD-40 isn't going to get "in" either.
After some squarely placed hammer blows, use a large open end wrench on the square head. Don't jump on the wrench or simply try to loosen it. Turn it "in", then "out". Work in small arcs as it breaks free so you hopefully don't pull out a big wad of aluminum when it comes free. I think you will find this easier to do (and safer) if you jack up the right-front corner of the car as high as you can and place it on stands. The clearance to the ground will give you more room to work. Keep in the back of your mind that the bolt will unscrew counterclockwise and that almost every Mini owner who changes their own oil has cut or badly bruised themselves on the front/nose panel when the sump plug suddenly breaks free. Leave room for yourself so you don't whack your hand.
