Domino Ht Complete Rebuild
#16
Posted 05 September 2008 - 11:13 PM
#17
Posted 06 September 2008 - 08:32 AM
all the work that has been done to date can be seen in the post "Something Different". its nice to find someone else on here with a Domino! it would be good if there is any information that you think relevant to our build that you could pass on....
#18
Posted 06 October 2008 - 01:26 PM
#19
Posted 28 January 2009 - 06:59 PM
After several months of running the engine in, getting the MJ ignition system set up, and other minor adjustments, I decided it was time to tackle the doors... again.
Originally, I'd done a quick refurb of the Domino's half metal/half fibreglass doors - removing rust from the metal, rebuilding cracked sections, etc. But one problem that I wasn't able to solve was that of the drivers side door simply not fitting very well. The upper frame stuck out a fair bit, causing much annoyance whenever it rained. Not wanting to totally remove and re-bond the fibreglass outer section of the doors, I wasn't able to bend the frame into place.
Another problem had also slowly been getting worse - the fibreglass outer was separating itself from the metal inner, despite my best attempts at rust proofing.
Rather than attempt to patch up the problem, I decided to start from scratch, with a pair of fully fibreglass doors that I'd modify to fit: in short, the removal of around two inches from the bottom of each door, plus the addition of the Domino's trademark sill 'bulge'. With the disappearance of Domino Cars, there was little chance of finding new outer door shells - the simplest solution, I decided, was to just cut this detail from my existing doors and attach it to the new.
I got the doors themselves from this forum - 'The Arc Angels' provided a pair with thick fibreglass walls, along with a smart looking solution to the door opening and locking mechanism. Seemed a real shame to have to cut them up!
Polycarbonate windows would also be necessary with these doors - although in my opinion, fitting heavy glass windows into fibreglass doors would be a mistake anyway. Plastics 4 Performance supplied the windows, standard 4mm polycarbonate with little lockable sliders. These would also need a fair amount of trimming to fit - in order to maximise the strength of the doors, the entire window frames were solid.
So, to photos (I've linked to them to save a bit of page loading)!
Untouched doors,
Marking the section to be removed...
... and, with help from a jigsaw, the end result!
Butchering the existing doors - there's no turning back now.
Test fitting the bulge on one of the new doors,
Making the mountings for the polycarbonate windows - these would be screwed and bonded onto the door frame.
Shaping the old fibreglass pieces to fit flush against the new Arc Angels doors.
Epoxy putty is a very handy substance when shaping large areas...
Next step... cutting the windows down to shape, and getting to doors off to painted (not to mention a new clutch and flywheel needing to be be fitted). Hopefully this will all be done before the next West Kent run on the 15th of Feb.
#20
Posted 28 January 2009 - 07:29 PM
#21
Posted 30 January 2009 - 01:06 PM
An uncut window on top of a door. Quite a lot of polycarbonate needs to be lost!
One down, one to go.
Just how practical the sliding windows prove to be on a road car remains to be seen. But I think they're going to look interesting!
Weight-wise, a fibreglass door plus polycarbonate window weighs just a bit more than an empty metal door. These are the Arc Angels heavier doors, with especially thick fibreglass in the important locations.
Edited by atom, 30 January 2009 - 01:07 PM.
#22
Posted 07 February 2009 - 09:07 PM
Fingers are crossed.
Anyway, here are the doors as they were, ready to be painted. The bag contains wing mirrors that will be painted the same colour.
Meanwhile, I've been painting the black border around the edge of the windows, hiding the mounting brackets and matching the black borders on the rear polycarbonate quarterlights.
It's black plasti-dip, which gives a rubbery end result. And which stinks.
#23
Posted 10 July 2009 - 09:05 PM
#24
Posted 11 July 2009 - 08:18 AM
keep it up
