Fitting a center speedo?
Posted 27 February 2004 - 06:44 PM
Mine is an 89' racing flame, and I *think* the car its from was a mini city, but im not 100% as I saw a few cars at the scrapyard today.
Also, does £10 seem like a reasonable price, thats how much the guy said,
If It cant be fitted to mine, and this is a good price, does anyone else want it? and ill pick it up for them, as long as they pay delivery.
pEaCe
Dom
Posted 27 February 2004 - 08:15 PM
The hardest bit is wiring it all up. If you can, then the plug and wires that are on the back of it too, then its just a case of joining the wires to your loom.
I tried converting from centre speedo to later type once, but it didnt work quite right. But then again I'm not a sparky and i didnt know what I was doin!
Posted 28 February 2004 - 03:44 PM
Right , ive got it out!! With the surround and everything.woohoo.
Unfortunately I was loosing too much blood and getting too cold to try and get the cable off the gearbox. I could reach it, but my numb fingers couldnt turn it with enough strength, lol. I might go back for it if I definately need it.
Ive got all the wires though I think, there is a white connector on the end.
Should I just be able to plug the connector from the old instrument cluster into this one?
Also, I have a rev counter on my mini, will it be ok just to leave this off? I
never use it anyway, thats what my ears are for, hehe.
Does anyone know where I can get a diagram of the back of a center speedo?some of the bulb holders have come out of the sockets, and im not sure which ones are which.
I think all of this will be worth it in the end, I think the centre speedos look so much better than those nasty 3 dial black boxes.
pEaCE
Dom
Also, ive been thinking about building a two part (left and right)dashboard with a 6x9 either side of the centre speedo (If they will fit, havent looked yet) Does anyone know if anyone has done this before? Ive never seen it done.
thanks again.
Posted 29 February 2004 - 10:15 AM
Im going to have a poke about today and see if I can figure it out, then all I need it a temperature gague and Im sorted, hehe.
pEaCE
Dom,
Posted 29 February 2004 - 01:46 PM
Any suggestions?
pEaCe
Dom
Posted 29 February 2004 - 02:54 PM
Al
Posted 29 February 2004 - 05:21 PM
thanks again ,
pEaCE
DOm
Posted 01 March 2004 - 03:59 PM
Ok in this pic you can see that I have already cut out the major rot. To make a template of the piece you need to fit in your hole just stick some cardboard behind it and draw with a marker.(quite simple) Oh. be sure to measure where the hole goes before you cut it all apart. for example using a paint marker jot a line on the inner fender wall somewhere and measure to the center of the vent hole, then jost right the figures on a piece of paper and don't lose em. To check what needs to be cut out use a pointed hammer and hit the areas and if it feels good and solid leave it...you can always just grind surface rust off.
Al
Posted 01 March 2004 - 04:07 PM
Al
Posted 01 March 2004 - 04:41 PM
Do you think it would be at all possible to repair this from inside the car?
My wings are in quite good condition and it would be a shame to have to remove them.
Thanks a lot,
pEaCe
Dom
Posted 01 March 2004 - 04:47 PM
Al
Posted 05 March 2004 - 11:34 AM
I think ive got a leaky windscreen seal, and thats where the problem has come from,
pEaCe
Dom
Posted 20 March 2004 - 11:49 PM
Siggy
Posted 21 March 2004 - 11:23 AM
Thanks a lot,
pEaCE
DOm
Posted 21 March 2004 - 02:35 PM
any problems, let me know and i will go and double check mine.
