Just Had An Absolute 'mare With An "easy" Bleed Kit!
Posted 14 September 2008 - 01:51 PM
Thought i'd renew the front discs, pads and hoses for goodridge braided ones. All done and on the car after a LOT of messing about trying to get the old hoses off the brake pipes - a very aqward job!
Put the "eezeebleed" kit on and its supposed to run off the pressure form a spare tyre, but no more than 20psi... Hooked it up and all it does is shoot its cap off the top of the brake resevoir and get bloomin fluid everywhere ARGH! There was hardly any pressure in the tyre either!!!
Annoyed as i can only work on the mini at weekends and i'm busy for the next two so thats another 3 weeks of "Wanda" off the road!
Moral of the storey is DO NOT BUY AN EEZEEBLEED KIT! lol!
Rant over,
Matt.
Posted 14 September 2008 - 01:55 PM
Also i found that i had to tighten the nut that gets the pipe connected to the cap as it was very loose?
Posted 14 September 2008 - 02:03 PM
Moral of the storey is MAKE SURE YOU SELECT THE RIGHT SIZE CAP! lol!
Just modified it for you.
Posted 14 September 2008 - 02:06 PM
Posted 14 September 2008 - 02:10 PM
Posted 14 September 2008 - 02:13 PM
you sure the cap was on straight??
Posted 14 September 2008 - 02:17 PM
I had the right cap on but I had to lower the pressure to less than 10 psi or it leaked everywhere or blew the cap off.
Blooming nightmare but persiveered and got there in the end.
Posted 14 September 2008 - 02:23 PM
Posted 14 September 2008 - 03:15 PM
Posted 14 September 2008 - 03:41 PM
Never got on with these so I bought one of those hand vacuum pump jobs - had it 20yrs, works a treat.
Hmmm sounds like a plan... any ideas where i can get one?
Posted 14 September 2008 - 05:09 PM
Posted 14 September 2008 - 06:08 PM
Posted 14 September 2008 - 07:36 PM
Posted 14 September 2008 - 08:16 PM
As far as I know the standard caps that come with an Easy-bleed don't fit a Mini and you need to send off for one of the other caps they make.
Think it depends where you get your kit from. I got mine form Moss and it came with about 5 or 6 caps and one of them was spot on!
Posted 14 September 2008 - 08:18 PM
Stupid thought!!
You did unscrew the bleed nipple???
