Just Had An Absolute 'mare With An "easy" Bleed Kit!
21 replies to this topic
#16 Rhyd
Rhyd
  • 482 posts
  • Local Club: Medievil Minis (Warwickshire)
Posted 14 September 2008 - 08:20 PM
Mine had 3 caps, one fits perfectly and the others are nowhere near the same size.
Is your master cylinder plastic or metal?
#17 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 14 September 2008 - 08:24 PM
Got mine from a local motor factors (Sparesworld) and mine has 3 caps with one fitting just right.
It even mentions the original Mini within the text. Can't remember why now though?
#18 jonny d
jonny d
  • 1,148 posts
Posted 14 September 2008 - 09:39 PM
Mine keeps leaking air out of the air valve fitting so i have to keep inflating the tyre. I have found the kit to be a bit cheaply made so i don't use it
I think I had to use an old cap and just drilled a hole in it as the kit never had one that fitted a mini but my kit is an old one though
#19 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 15 September 2008 - 07:59 PM
Got mine a few weeks ago (gunson eezibleed) from halfords - while I'm here why have they named it like "itz sumting u by frm da streetz?" :thumbsup:
Anyways, you get 3 clear hoses of different diameters and 4 caps of different sizes as below
And Taffy is right its mentions a mini.......point 5
I havent used it yet but hopefully it will be eezi! As I dont want fluid spraying over the car!
Otherwize I iz guna hve 2 dig a bro 2 pop down wis dis and helpz out wiv da car.
Man I'm so street....... :thumbsup:
#20 Waffs1984
Waffs1984
  • 437 posts
Posted 15 September 2008 - 08:11 PM
Yeah mine came with an assortment of caps but the only two that were the same size as the resevoiur neck screwed on but then blew off under any sort of pressure!
Yeah i had the bleed nipple open and like i said i had it woring under an asthmatic level of pressure for about 30secs :thumbsup:
I got mine from minispares though so would have though it would have a "mini" cap in there!
Its a plastic brake fluid resevoir by the way....
Cheers,
Matt.
#21 Kam
Kam
  • 4,140 posts
Posted 15 September 2008 - 08:54 PM
Cheers,
Matt.
Pm Simon@minispares on here, I know the text on mine just below the contents say that "other caps are available should these not fit?" So it should be in there, They probably can advise you further?
Hth
#22 giz
giz
  • 747 posts
  • Local Club: ubmc
Posted 15 September 2008 - 09:23 PM
bought mine fom halfords too, i've never checked the psi on my tyres either. it's never blown off and i think they're a great tool to have.
