Handbrake Not Right
41 replies to this topic
#31 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 September 2008 - 10:41 PM
so if this is the cause, how does one fix it?
#32 lrostoke
lrostoke
  • 6,923 posts
The bad news is, if the thread on the backplate is stripped, then new they are about £33 :(
If its the adjuster "bolt" then shouldn't think they are much.
But it does sound like a stripped thread somewhere, the 5mm movement is the corners of the adjuster peg pushing the shoes out.
Not sure what 2nd availabilty is like..They have a nasty habit of seizing solid those adjusters.
#33 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 September 2008 - 10:48 PM
will ebay it see what sort of price im looking at
how do i get the adjuster out to see which thread has gone e.g. backplate or adjuster?
#34 Ethel
  • 26,078 posts
Posted 20 September 2008 - 10:57 PM
A new back plate isn't so bad. Apparently Metro ones fit, they have a separate, bolt on, adjuster - but that costs as much as a Mini backplate.
The adjuster unscrews, if you took the backplate off you could arrange it to push as well as turn it, which may help. That means disconnecting the wheel cylinder of course.
#35 lrostoke
lrostoke
  • 6,923 posts
Posted 20 September 2008 - 11:01 PM
Metro ones do fit, not sure what years though ??
We fitted Metro backplates to my sisters, got whole backplate assembly, shoes, handbrake spreader, cylinder .£10 for a pair local scrapyard.
#36 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 September 2008 - 11:09 PM
to be honest if i gotta get a new one id rather get a NEW one if ya get me lol
but lookin on minispares im now somewhat confused lol
says i need this and that, if i was to get a new backplate off minispares what other things would i need to buy with it
#37 Ethel
  • 26,078 posts
Posted 20 September 2008 - 11:15 PM
Looks like they used the same shoes and cylinders up to the very end (Rover 100) so could be an option. The rear cylinders are a different bore though.
You wouldn't need anything, save any bits that aren't reusable of course.
(Since I got this moderator status I've used it on more of my own posts than any others combined :( )
#38 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 September 2008 - 11:18 PM
Looks like they used the same shoes and cylinders up to the very end (Rover 100) so looks like an option. The rear cylinders are a different bore though.
that are reusable dnt u mean?
does haynes cover how to remove the backplate?
#39 Ethel
  • 26,078 posts
Posted 20 September 2008 - 11:24 PM
Nope, I got that the right way round ( :errr: I think)
Yeah it'll be in your haynes - just 3 nuts 'n bolts once the hub is off. The only bit likely to cause any grief is removing the wheel cylinder - sometimes the pipe doesn't like it if it's corroded.
Aaaah, by save I mean "apart from" not "keep" :(
#40 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 September 2008 - 11:43 PM
im new to the mechanic side of life so treat me like an idiot
whats a hub :(
and i take it ur on bout the retaining clip with regards to the wheel cylinder
Edited by stormintrooper, 20 September 2008 - 11:52 PM.
#41 Ethel
  • 26,078 posts
Posted 21 September 2008 - 12:26 AM
Well the clip can be a pig too, but if the brake pipe is rusted in to the pipe union if tends to twist when you undo it. Best to replace the pipe, but holding the union still and unscrewing the cylinder (once the clip is off) may do the job.
The hub is the spinny bit with the wheel studs in - again it'll be in your Haynes :dontgetit:
None of this is any harder than fitting brake shoes.
#42 Grayedout
Grayedout
  • 901 posts
Posted 21 September 2008 - 07:49 AM
Dont think it has been mentioned but mkae sure the joint in item 7 in the diagram above is very free and greased and moves easily.
