Fuel Gauge Reading Low...
18 replies to this topic
#16 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 10 October 2008 - 08:04 AM
You don't need a dipstick - just get a torch and peer into the filler neck - you should easily be able to see the back of the sender unit and establish when the petrol level is below it.
I used a bamboo cane for a while :thumbsup:
#17 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 10 October 2008 - 08:25 AM
Well, my new sender is on the way from MiniSpares, so it's just a matter of letting the fuel go low and putting it in there.
I've been trying to work out what sort of MpG figure I'm getting - so that I know how far 34 litres will go....
In my boring work Diesel Peugeot 307, I get 500-600 miles to a tank.. so once the trip meter reads 500, I dutifully go fill up.
I was looking a similar idea in the mini - but no trip meter. Ho hum.
What MpG figures do you get??
#18 daemonchild
daemonchild
  • 2,341 posts
Posted 10 October 2008 - 08:33 AM
A torch? Real men use a *match*.... :wub:
(And prepare to travel quickly.)
#19 Boycie
Boycie
  • 1,978 posts
Posted 19 October 2008 - 09:46 PM
Ok, I've finally got round to fixing this.
It was actually two seperate problems.
First off, the float had gone porous, and had a bit of fuel inside it. However, the real problem was with the voltage stabiliser located in the (nippon) gauges.
I fitted a new sender and was dismayed to find it had only improved matters slightly. Luckily, I had a nice set of Clubman gauges (Smiths) and swapped them over. Finally- a properly working fuel gauge. And... as an added bonus.. the temperature gauge now sits in the middle! :shifty: I thought that problem was a duff 'stat.
Anyway, all I can say is, it's well worth sorting out- makes the car much more useable if it's your 'daily'. :shifty:
