Rover Mini Sportspack/wheel Bearings
Posted 21 April 2009 - 07:06 PM
I have a 1999 rover mibni sportspack with 13 inch wheels, but i have ongoing problems with the wheel bearings going! I have replaced the drivers side ones three times now and one/twice on the passenger side. I have only had the car a year and we r fed up of spending out on wheel bearings every few months.
I know the 13 inch wheels have more problems than say the 10's the weight etc and the low profile won't help either.
But it does seem odd that they r going this regularily. As my other half has an 1983 austin mini and his wheel bearings last forever and yes his are on 10 inch wheels.
But What could be wrong, can anyone help. Has this happened to anyone with a sportspack??
chloe
Posted 21 April 2009 - 07:29 PM
Rob
Posted 21 April 2009 - 07:38 PM
Help!
Posted 21 April 2009 - 07:51 PM
Posted 21 April 2009 - 07:55 PM
Posted 21 April 2009 - 07:57 PM
what is so special about drum brake bearings? can you explain the difference?trade secert is to use drum brake bearings and the problem goes away
Posted 21 April 2009 - 08:00 PM
Rob
Posted 21 April 2009 - 08:08 PM
oh sorry my mistake the grease was supplied with the drivers side bearings which was non genuine! we did use castorol grease for this bearing which is in question. And torqued upto the haynes manual guide.I use timkins..... and their is NO grease supllied, its a bearing and normally bearing suppliers supply bearings not kits...... if i was you Id order bearings from M Machine or Minispares......... they wont come with grease...... get some Castrol LM and pack the bearing correctl..... what torque ar you doing the castle nut up to?
Rob
What do u mean by packing, is there a particular way of application ?
Posted 21 April 2009 - 08:18 PM
Rob
Posted 21 April 2009 - 08:21 PM
still i hope it helps you out Rustic's missus
Posted 21 April 2009 - 08:47 PM
I use Timken bearings the secret is to NOT fit the coned washer but to tighten using a flat washer go for a cup of tea...... then gently remove flat washer and lightly grease cone washer and nut and torque up.....
However I would now suggest that before you do any of this you need to check your CV joints, as I am sure they will have been damaged by the bearings running on them
also take a look at CV fitting in this forum
I have laid out exactly what needs to be done a few times now in quite some depth
Fitting roller bearings in a sports pack will simply wear out quicker.
Posted 21 April 2009 - 08:49 PM
Rob
Sorry Rob, I have had a quick look through my stock and they all come with grease
Edited by mra-minis.co.uk, 21 April 2009 - 08:49 PM.
Posted 22 April 2009 - 07:58 AM
We followed what the haynes manual said.
chloe
Posted 22 April 2009 - 10:36 AM
