Engine Swap Ideas
Posted 10 March 2010 - 06:20 PM
any ideas or links to projects where people have already done similar would be nice i know that the vtec and vauxhall engines are popular bit there no real point in putting that much power into sumthin that lite so sumthin around 1 - 1.4 would be ok i would also change petrol tanks so diesel could be an option
Posted 10 March 2010 - 06:54 PM
Posted 10 March 2010 - 06:59 PM
Posted 10 March 2010 - 07:04 PM
Posted 10 March 2010 - 07:55 PM
the only other thing would be that at the moment the mini is just drinking petrol and its a fully rebuild engine although it hasn't been on the road in 20 years and this has been its first thousand miles since the early ninetys i wouldn't want too be have the same mpg issues with a larger more expensive to tax engine but maybe its just my engine so would you let me know what you guys 1275/998 engines run like
Posted 10 March 2010 - 10:46 PM
If you want 5 gears you could get a 1275 and a 5 speed box from minispares or the like but again, these are very expensive. What kind of money are you looking at?
You shouldn't really have a problem at the moment. Fair enough 4 speed can be quite uncomfortable on motorways due to engine noise, but there's no reason it shouldn't be happy to cruise along at 70 all day. I've only ever had 4 speed cars, and although I curse that my ears are bleeding, they don't let me down. 5 gears would be great, but is it worth the cost? How many times are you going to be using motorways or dual carriage ways?
With regards to your engine, if its being used as a daily after being stored for many years, its going to need a good full service, and be prepared for parts to start failing here and there. It's nothing to worry about, just that after so many years of standing, parts are going to be past there best. I've had this on mine. It's just something you have to work your way through. If you still have low mpg figures and things dont seem right, take it to a place like ML Motorsport to tune it up.
When my mini was feeling a bit sluggish, I took it to ML at SMD a couple of years ago. They asked a few questions then said the tuning is way out simply because I had replaced the carb, dizzy etc to get it running, and it needed 'fine tuning to the engine' as such. I think they called it an 'Optimisation Tune'. However I never got to get it tuned, but i have heard very good things. I would suggest you do this before considering anything else and see what you think.
Oli
Posted 10 March 2010 - 11:12 PM
Posted 10 March 2010 - 11:15 PM
I test drove an MG Metty I was going to buy for the engine two days before my accident, so i never got round to that either...but it was quite a nippy little thing. for some reason the owner got rid of the original alloys too so it was on skinny steels, que lots of tyres squealingOn the money side buy a MG 1300 Metro Lump and box red one with alloy rocker cover only still 4 gears and tune it down.The drop straight in .And fit a couple of mounts so easy.
Edited by oli8925, 10 March 2010 - 11:15 PM.
Posted 11 March 2010 - 10:32 AM
i had the car retuned after my crash at christmas by a man who is knwon as the godfather of carbs in northern ireland but i never got it redone after the head gasket went so she probly needs it done again.
the engine has been completely rebuilt and it only has 50,000 miles so i would like to think that these problems are just a temperay thing
i know where i can get a late 1275 cheap, my next door negihboor as it happens has no in the back of his garage but i haven treally seen or heard much detail on it my engine is spi and am no machanic so i would just there would be a couple of expensive parts that would need to be bought.
Edited by big tobby 7592, 11 March 2010 - 10:59 AM.
Posted 11 March 2010 - 11:14 AM
Posted 11 March 2010 - 11:53 AM
Posted 11 March 2010 - 01:40 PM
Posted 11 March 2010 - 01:49 PM
Posted 11 March 2010 - 02:20 PM
Some do not know how to spot a 100 from a 1293.Thats up to you.You must fit the 2 mod. Brackets at the same time to be safe and save your exhaust pipe...
Posted 11 March 2010 - 04:53 PM
Well its always best to look into all options like a real sport.The Insurane does go up a lot and they must have the front Discs.For better Fuel returns you could just change the carb.Electronic ignition kit Electric fuel pump and 13" wheels.For power you should be happy with the MG metro lump.
i have 13 inch super lites and front disc heres my car http://www.theminifo...p;#entry1759075
tell me more about this electronic ignition
