Rover 3.5 V8
#91
Posted 20 July 2007 - 12:09 PM
oil was changed 70-100 miles ago after the old ECU packed up and filled the engine with petrol.
hoping its the pressure valve, as that should be an easy fix
#92
Posted 20 July 2007 - 12:11 PM
#93
Posted 06 August 2007 - 06:58 PM
im thinking of doin the same thing to my mini pick-up truck please could you help with information an what engine and gearbox has been used thanks
#94
Posted 17 August 2007 - 10:36 PM
i was thinking problem was due to oil pickup being clogged up.
spent a few hours getting the gearbox end plate off to get to it. just needed that little bit extra clearance to get it off, but couldn't find it. eventually it was off and there was a reasonable amount of C**p around the pickup pipe that would have been enough to restrict oil flow and pressure.
i used quite a fine gauze over the pick up, so replaced it with some out of a gearbox i got with the clubby estate. have got this in place, just need to put the reat together tomorrow, and give it a run to see if its a fix.
if alls well it will be the first time its been driven to a show
#95
Posted 17 August 2007 - 10:44 PM
#96
Posted 17 August 2007 - 10:47 PM
but i had better sit in the passenger seat to balance out the car.... *scrolls eyes*
if your desperate for lift the wife and kids have plenty of room left in the Bongo
#97
Posted 17 August 2007 - 10:48 PM
lmao. DAMN! Might have to take you up on that still
#98
Posted 17 August 2007 - 10:54 PM
lmao. DAMN! Might have to take you up on that stilllol.
if the mini is going for sunday you could be a passenger
we will be leaving early, clubs meeting at Brackley tescos to leave at 8.30am
we will be leaving banbury about 8.00am
#99
Posted 17 August 2007 - 10:57 PM
are you on a stand with it? Your local club one again?
#100
Posted 17 August 2007 - 11:00 PM
if the mini is going for sunday you could be a passenger![]()
would be brilliant man. Keep me in the no huh! ill pm you my house number. Ill giv u a lil petrol money if you want. Just dont get carried away with you right foot
#101
Posted 17 August 2007 - 11:04 PM
Yay!!! I do love watching peoples faces when they see whats in it, and even more so when you start it up
well it still looks basic and unsuspecting, so should still get some odd looks.
if it gets there we will be on the "Minis On The Run" stand.
wondering how many people will ask if its going up the strip (not, because the clutch still slips)
and how many ask what gearbox i've used
#102
Posted 17 August 2007 - 11:13 PM
I dont want to test my driveshafts up the strip, although they have been ok since.
Also with a stock engine i dont think id be up to much especially with my huge flywheel
Mine should be on the 16vMiniClub stand (along with my brothers)
#103
Posted 19 August 2007 - 08:13 PM
my mini got there ok, was just hot and noisy. coming home started to get a bit of noise on the N/S rear, so i think the rear wheel bearing / hub is knackered.
plus i've got an intermittent noisy tappet. mostly its ok then it will start tapping for no reason and the stop, some times on it own, or sometimes it needs a bit of revving to get oil pressure right up to cure it. so i assume i've got a doggy hydraulic lifter.
Ed, i didn't come across the 16v mini stand, did mean to find it, i'm after some ideas for the clubby estate (dont tell the wife) thinking vtec maybe if the V8 goes one day
#104
Posted 19 August 2007 - 08:22 PM
Didnt manage to get around all the club stands, spent a while talking to people at the 16v one (quite a bit of interest!!).
Glad to hear it went ok and that the oil problem seems to be fixed
