Any ideas how the ignition side of things works Mike? I know it can work with the EDIS system, but i dont really want to add another trigger wheel and sensor if possible.
You dont need edis with the vauxhall. The megasquirt has an inbuilt parameter in it, that allows you to run the original vauxhall crank sensor. All you would need to do is decide if you wanted to go for the hall effect dizzy off an earlier XE or the later Dispac coilpack. Personally im going the dispac route.
Edited by RacingGreen, 01 October 2009 - 07:19 PM.
