Knocks When Revving
45 replies to this topic
#1 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 05:42 PM
Hi guys
just pulled away from the garage and got an awful knocking noise.
It only happens when I am accelerating or increasing the revs of the engine
It is very loud and I am out of ideas as to where to look first.
I checked under the rocker cover and all seems fine
There is slight play on the pulley of the water pump (is this normal)
how can I check it is the water pump. Can I disconect the pully on it some how to check?
Any ideas please
ta
Lloyd
PS
City E 998 1989 plate Has a modified head on it
I think that is all the details of the car.
Been stood for 18months just done its first 40miles in last two days
#2 jaydee
jaydee
  • 8,565 posts
Posted 16 May 2012 - 05:56 PM
Possibly engine steady bushes are shot or the engine mountings are gone or not tight, those can be the caus of the knocking.
The pulley should be tight, but exactly where do you feel the play?
#3 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 06:16 PM
i just held the pulley and gave it a wobble and could feel movement, but am not sure if it is just normal tolerance
the knocking is in time with the revs so i am doubting engine steadies or mounts
#4 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 16 May 2012 - 06:20 PM
Is it possible for you to post a video?
#5 Fen Buzzard
Fen Buzzard
  • 69 posts
Posted 16 May 2012 - 06:23 PM
Does this happen while you are in gear and traveling or while you are stationary?
#6 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 06:36 PM
give me 30 - 60 min to get the kids to bed
both, while driving or sat stationary just reving
#7 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 06:39 PM
Check oil level first
does it go away when clutch pressed ?
is it a low hollow knock , a rumble , or a tap ??
any recent oil light when driving , or if you have a gauge what is the oil pressure - warm at tick over ??
Edited by sledgehammer, 16 May 2012 - 06:45 PM.
#8 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 06:47 PM
oil level is good
its a quick knock in time with the revs getting faster and then stopping when you stop increasing revs or stop accelerating
what ever it is it is when the engine is under load i think
It is quite loud and distint. Also you can hear it inside and outside that car. I got a few odd looks as I drove the mile home with it.
#9 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 07:00 PM
I really hope I am wrong - but it sounds like a big end going / gone / spun
but without being next to the car , I can't say for sure
I hope I am wrong
Edited by sledgehammer, 16 May 2012 - 07:01 PM.
#10 Fen Buzzard
Fen Buzzard
  • 69 posts
Just read your OP again, if the water pump impeller fails it can cause a noise but its more of a grinding noise increasing with the engine revs.
#11 jaydee
jaydee
  • 8,565 posts
Posted 16 May 2012 - 07:02 PM
What sort of work they did at the garage?
#12 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 07:04 PM
good idea - slacken the fan belt - then remove it - & try engine again
#13 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:06 PM
none, it was an MOT re-test. It drove 20miles no bother, guy passed it after walking round it. Then I pulled away and got the knocking
#14 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:07 PM
I hope I am wrong
For it to start so suddenly, i am not sure. is there any checks i can do to rule it out?
#15 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:09 PM
do you mean start the car, with no fan belt (will it start/run?) to rule out the pump and alternator?
