Knocks When Revving
45 replies to this topic
#31 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 17 May 2012 - 01:11 PM
I've had teh HG blow between just the bores, it sounded just like the big ends had gone (fooled teh RAC guy).
#32 coopersmate
coopersmate
  • 408 posts
Posted 17 May 2012 - 01:22 PM
It is worth a check tonight, I guess a compression test will spot that for me, before I strip the head down
#33 jaydee
jaydee
  • 8,565 posts
Posted 17 May 2012 - 04:30 PM
I'm with Craig, check the head gasket.
#34 coopersmate
coopersmate
  • 408 posts
Posted 17 May 2012 - 04:55 PM
So am I given the work involved between a head or crank shaft shell
#35 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 17 May 2012 - 06:24 PM
Hi,
A blown head gasket between 2 cylinders can give a sound very like knocking big ends as craig 1010 said.
The "explosion" from the firing stroke of one cylinder can cause a sudden high pressure "wave" against the neighbouring piston and this shock can cause this kind of noise. It's a bit like very heavy pinking!
A compression check will immediately show if the is a break between two cylinders, so you'll get 2 good readings and then on the affected cylinder pair a poor reading on each of the cylinders.
If this is the case, continuing to run the engine like this will cause a "hot spot" between the cylinders in either/both the engine/block which can render both scrap!
Cheers,
Steve.
#36 coopersmate
coopersmate
  • 408 posts
Posted 17 May 2012 - 07:05 PM
just done a compression test - cylinder one 190 psi, cylinder two 190 psi, cylinder three 30 psi, cylinder four 30 psi.
I think I've got a head gasket blown, time to strip the top half of the engine to see if I can get this sorted for London to Brighton!
#37 03jkirk
03jkirk
  • 465 posts
Posted 17 May 2012 - 07:10 PM
good to hear that its not anything more serious and lets hope there no damage to the head or block between the cylinders
Edited by 03jkirk, 17 May 2012 - 07:11 PM.
#38 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 17 May 2012 - 07:15 PM
snap! im doing excatly the same sat!!
cyl 1 170,cyl 2 170, cyl 3 000, cyl 4 000
#39 coopersmate
coopersmate
  • 408 posts
Posted 17 May 2012 - 09:13 PM
Are you aiming for London 2 brighton as well?
looks alright but will contact a machine shop tomorrow and see if it can be decked, then i am thinking one of those black sticky gaskets, what are they called?
#40 03jkirk
03jkirk
  • 465 posts
Posted 17 May 2012 - 09:48 PM
best stickin with a good quality copper head gasket
#41 jaydee
jaydee
  • 8,565 posts
Posted 17 May 2012 - 09:53 PM
Composite gaskets they're called.
You'll be fine even with the cheap gasket on a standard engine.
Just have the cylinder head skimmed a few thou, degrease the deck, and torque up the nuts in increasing settings, 30 then 40 then 50.
#42 sledgehammer
sledgehammer
  • 3,129 posts
Posted 17 May 2012 - 10:27 PM
sounds like fire rings burn't thru / leaking
suprised you didn't notice a loss in power / poor starting
glad to hear it probably wasn't the ends
#43 coopersmate
coopersmate
  • 408 posts
Posted 18 May 2012 - 06:57 AM
Thanks for the advice lads. I will proberbly get what I can get hold of as the work needs doing tonight. Then sheffield to crystal palace to run it in :xmas:
car has been stood for 18 months and had trouble starting but that was battery and cold winters mainly. It did appear to just go. I am also very happy it wasn't the big ends
#44 coopersmate
coopersmate
  • 408 posts
Posted 18 May 2012 - 09:11 PM
hi guys
just to update this. I have just changed the head gasket and the knocking is solved.
crystal palace tomorrow
come say hello
thanks for the help and support
ta
lloyd
#45 leroy26
leroy26
  • 2,239 posts
Posted 19 May 2012 - 06:46 AM
sweet ! ill crack on with mine then!
