Knocks When Revving
45 replies to this topic
#16 Fen Buzzard
Fen Buzzard
  • 69 posts
Posted 16 May 2012 - 07:09 PM
Just read your OP again, if the water pump impeller fails it can cause a noise but its more of a grinding noise increasing with the engine revs.
good idea - slacken the fan belt - then remove it - & try engine again
Sounds like a plan to me
#17 Fen Buzzard
Fen Buzzard
  • 69 posts
Posted 16 May 2012 - 07:11 PM
Yeah it will start and run fine. Just make sure you remove the belt completly so it doesnt get spun round with the crank pulley.
#18 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 07:13 PM
oil pressure may tell you if you have a gauge
do a oil change - or just inspect it (look for silver bits & metal particles) & refill
#19 coopersmate
coopersmate
  • 408 posts
Right back in 5
#20 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:14 PM
Right back in 5
#21 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 07:15 PM
Hope it is something cheap & easy - esp after you just got an MOT
#22 jaydee
jaydee
  • 8,565 posts
Posted 16 May 2012 - 07:18 PM
They forgot a spanner somewhere..ahhaha :P
#23 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:48 PM
no the spanner is in the drivers seat
right so here are two video's with and without the fan belt
there seems to be a difference but the knocking I think is still there
it has started to sound a bit exhaust hole like or something :mmkay:
with fan belt
no fan belt
#24 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 07:50 PM
no oil pressure gauge i am afraid
will the silver etc be the signs of the big end, as i have a fair amount anyhow with a warn sycro mesh
#25 03jkirk
03jkirk
  • 465 posts
Posted 16 May 2012 - 07:54 PM
there wasnt a bang wen it first happend was there?? smashed valve bouncin on piston mabye?? easy to check if take plugs out and have peak inside the bores.
#26 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 08:05 PM
not that i noticed. i have also had the rocker cover off and all looks in order with the vlalves, valve seats, springs and rockers
#27 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2012 - 08:10 PM
didn't hear a knock in that vid - just a weird sound
so hopefully not ends - maybe blowing manifold ?
#28 coopersmate
coopersmate
  • 408 posts
Posted 16 May 2012 - 08:20 PM
phone videos are pants
I cant see any issues on the manifold or first joint on the exhaust
sound was less without the belt but still there
#29 jaydee
jaydee
  • 8,565 posts
Posted 16 May 2012 - 08:22 PM
Could be many things, i can hear the audio very verry well, but it can be either the water pump or the timing chain tensioner. It needs further inspection.
#30 coopersmate
coopersmate
  • 408 posts
Posted 17 May 2012 - 11:25 AM
Hi
Just had the car at a garage to get a second opion and he said we thinks its big or little ends.
He didn't want to garentee that as he wasn't a mini specilist.
So is there anyone in or near sheffield that could do me a favour and come for a listen to give me an opion.
I will bring it to another garage as well and see what they say.
ta
Lloyd (gutted) :ermm: :!:
