Steering Jumping ?
Posted 23 May 2012 - 01:10 PM
thanks danny
Posted 23 May 2012 - 01:38 PM
I have seen a very badly worn CV joint on a Talbot where there was no grease at all, just rust and that made some very weird knocking noises and it made the car jump when turning the steering. Whip the gaiters off and have a look.
You could disconnect both of your track rod ends and check your steering rack to see if that is the culprit. What ever it is do not drive the car until you find the cause of the problem.
Posted 23 May 2012 - 03:31 PM
I hope you have not fitted a steering column drop bracket, or done any work on the column, without loosening both rack U bolts. A rack misaligned to the steering column can cause binding, but far, far worse, is guaranteed to cause sudden and complete steering failure fairly soon. The reason that I mention it is that there have been far too many cases of that on the forum recently, and if people keep getting such a basic thing wrong, it is only a matter of time till someone is killed.
Posted 23 May 2012 - 08:04 PM
hope that makes sense on my phone so bit crap
thanks
Danny
Posted 23 May 2012 - 08:05 PM
thanks Danny
Posted 23 May 2012 - 08:14 PM
Posted 23 May 2012 - 08:16 PM
Danny
Posted 23 May 2012 - 08:17 PM
Posted 23 May 2012 - 08:18 PM
Posted 23 May 2012 - 08:32 PM
Danny
Posted 23 May 2012 - 09:10 PM
Posted 23 May 2012 - 09:12 PM
Posted 23 May 2012 - 09:15 PM
Obviously investigate the diff further before you pull the engine out!!
Guessworks - where have you gone?
Posted 23 May 2012 - 11:39 PM
thank Danny
Posted 24 May 2012 - 12:02 AM
But to do that, or lift the engine, the driveshafts have to come out anyway. I still think the symptom is EXACTLY that of a failing CV. They don't lock until the balls are not lying in the same plane, which may take several revolutions at a small angle. Please do try to avoid what may be needless work by doing a simple check. Take the suspect drive shaft out, remove the CV, and remove its rubber boot. Turn the innards to every possible angle, and see how much sideways clearance the balls have in their slots. Two or more of the slots are quite long, to make assembly possible, it is not the length but the side clearance that is critical. Take it apart, and check the cage very carefully for cracks.
If it is the CV, you have saved many hours and a lot of money. If it turns out to be the diff, you have only added the cost of a tube of CV grease and a new boot clip to a very large bill.
Oh, and you might want to strip and check the inner pot joints too, although I don't think they are likely to be the problem. It is just about possible that one of them is defective, which might cause some effect on the steering.
