Steering Jumping ?
53 replies to this topic
#46 Carlos W
Carlos W
  • 10,115 posts
Posted 30 May 2012 - 06:07 PM
You got a spark?
#47 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 31 May 2012 - 09:38 AM
i gave up was just fed up lol think I've sorted it but battery flat now bloody thing haha
#48 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 01 June 2012 - 04:38 PM
its runs
sort of lol sorry for the wrong names here the thing that slids up and down was stuck down so i free'ed it up with plently of engine oil and moving back and forth and now its running when driving it wont go over 3000 without back firing through the carb could this be becuase i put 20w50 in the dashpot oil because i had nothink else ???
thanks danny
#49 Boycie
Boycie
  • 1,978 posts
Posted 01 June 2012 - 04:57 PM
Do you mean the carb piston was stuck Danny? The fact you have 20w50 in the dashpot is no problem at all. But if you had a siezed carb piston, I'd be whipping it all apart and making sure it's perfect in there, it needs to move totally smoothly.
Edited by Boycie, 01 June 2012 - 04:57 PM.
#50 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 01 June 2012 - 05:01 PM
ya thats was it ya i freed it all up and ran a dream but has started back firing at 3000 revs will take it out later and see if it is sticking
thakns danny
#51 Boycie
Boycie
  • 1,978 posts
Posted 01 June 2012 - 05:04 PM
Well it would make sense to make sure this is sorted perfectly first, as you've already had trouble with it. Then go into the ignition timing and check the plugs etc. Look on the bright side, it lives to fight another day :D
#52 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 01 June 2012 - 08:48 PM
well went halfords for spark plugs and it ended like this me in the white under it the driver bottom ball joint fell out the bottom arm the nut must have worked its way loose all fixed.now
#53 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 01 June 2012 - 09:11 PM
Sounds like it may be an inlet leak or timing
#54 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 01 June 2012 - 10:40 PM
i replaced all gaskets on carb and timing woundnt have changed would.it
