here you go . best i could get off my phone tonight. back end is literally one coat over the green with gun remnaants practising technique. it going to look bloody superb with proper prep :))
Painting The Mini
#16
Posted 14 June 2013 - 08:39 PM
#17
Posted 14 June 2013 - 08:53 PM
Your'e probably going to want to mask off your dash - clock - steering, shifter a whole lot better than what it is now - Overspray goes EVERYWHERE> including the headliner!
#18
Posted 14 June 2013 - 10:00 PM
yeah tah mate I will before doing the outside. all apertures will be fully masked
#19
Posted 15 June 2013 - 09:37 PM
did a bit on the doors today. Ive fit new doorskins and the edges are a little "pie crusty" due to use of the skinning tool. Ive cleaned the paint off, planished the high spots down, and put skin of filler on. if we get a good day tomorrow I can get them finished and high builded. slow and steady :)
Posted 15 June 2013 - 09:44 PM
Looks like you're making good progress there. What skinning tool did you use if you don't mind me asking?
#21
Posted 15 June 2013 - 09:57 PM
cheers, dont mind at all mate. borrowed one off my door skinning guru. Ill post a pic of it up tomorrow for you
#22
Posted 18 June 2013 - 11:30 AM
drivers door filled, etch primed, and high builded :)
Posted 18 June 2013 - 05:00 PM
cheers james
#24
Posted 21 June 2013 - 08:32 PM
took advantage of the weather today, scutched the back end back to bare metal, acid etch primed and high build primered. new valance so just needed stonechip overspray removing and keying in. knackered but happy now
Posted 05 July 2013 - 08:05 PM
Perfect day for painting today. roof poly disced back to bare metal ( 2 coats of paint and primer ) fortunately very little rust. acid etch primed and 3 good coats of high build. looked like the bloody incredible hulk after rubbing down, but on a serious note you can see the importnce of googles and mask LOL
Posted 06 July 2013 - 07:39 PM
#27
Posted 07 July 2013 - 10:12 PM
front end done in high build. o/s scuttle took a lot of time and bits of filler to get right. wing to scuttle joins have been filled with poly sealant :)
Posted 08 July 2013 - 08:18 AM
HUH! I've just put 3 and 2 together and realised I follow your facebook page some how BO.
#29
Posted 08 July 2013 - 08:22 AM
Also with the high build do use the manufactures flash time between coat then block back before the colour?
Hopefully i'll be getting to do the van in primer sooner rather than later and trying to gauge techniques.
Matt
#30
Posted 09 July 2013 - 09:38 PM
Ive just gauged the flash time with when it looks dry. If Ive been painting in the evening it can take 15 minutes. In the sun Ive had to add extra thinner and its been flashing off within 5 minutes. Ive been blessed with this weather :))
