I wanted to switch from the 2 clock cluster to 3 clocks so I can get a tacho. I bought one off MiniJosh that had magnolia dials and was a 110mph like the one I'm taking out so hopefully no problems with inaccurate readings (more than they were anyway
Also the speedo wasn't reading. Ive posted questions about it before. So I finally had to tackle it. I couldn't get it to go though. It had a new speedo cable fitted and looked good at both ends but just won't work. For a while it was the needle was jiggling up to about 10 miles an hour - even though we were doing more than that but then it stopped showing anything.
I took the new cable off the speedo and it ran the engine with the wheels jacked up. It turned fine. I gripped it and it kept turning so unlikely to be a break in the cable. Tested the speedo by putting the new cable on it and attaching it to a drill - all good. Tested the speedo in the 3 clock cluster I am fitting - all good as well. Took the cable out - my cable at the final drive end was very tight to I got underneath an managed to get a tap spanner on it enough to break the seal and start it turning, then did the rest by hand. Got a new cable on and just did that up hand tight. Plugged it in to the speed and all seems to be good. Will road test it tomorrow if the weather is good enough.
One thing I found looking at the old cable is that one way/ in one position only the square end of the cable would plug in to the speedo properly and all was good but anything other than that perfect position and it wouldn't engage properly so I think the square section was a shade on the large side. Whatever, it works now I think.
Also, I said previously that I was making a new switch panel. Got that all painted up and got the switches fitted to it. I cannot, for the life of me, find the bloody grommets I bought so I can't put the choke and heater cables back in yet which is really frustrating but that should be sorted tomorrow as I got them on express delivery from Minispares.
I also put the air filter housing in the dishwasher while the wife wasn't looking, put a new filter in and it's ready to go back on the car.
Last thing I did today was fit a nice shiny rocker cover. Good progress over the last few days. Really happy as long as the speedo works ok on the test run tomorrow. I'm going to run it against the gps on my TomTom to see how far out we are. I will stick up some picks tomorrow hopefully.
Oh, I can't remember if I mentioned it or not but I bought some stainless bumpers from Minispares and got those on. The front one flew on but the rear one doesn't fit in the middle of the bumper. Not a big problem but I would rather have had it connected.
I am desperately trying to get it ready to take back to Andy at ML Motorsports next weekend as I've completed running in the engine so it will have an oil change and be tuned up for proper running. Currently it has one of Andy's carb's on it as mine needed a set up. It will go back on just before the tune up.
Rod
