Hi
More electrical fun today.
Well I say fun - more confused scratching of head and questions.
On the positive side, I got the headlight wires identified and the side repeaters. I got the different coloured wires sorted for the fuse box and looked at where to position the uprated wiring loom I bought from Wired By Wilson for the headlights.
On the negative side, the new loom has spade connectors or bullet connectors in opposite places that have to the spades and bullets in various places. A pain but solveable.
My big problem is with the 5 switches for lights, rear window heater, fogs and so on, on the dash.
4 out of 5 have differences in the wiring when compared to whats on the loom versus what's in the wiring diagram AND the pins that are in the switches. I'm going to raise a question about it but it doesn't look right if the wiring diagram is to be believed. I won't go in to it all here but here's and example. If you look at the that the Hazard Switch then the wiring diagram says there are 6 connections. They are
1. light green/ brown
2. light green/ brown
3. green/ light green
4. green/ red
5. green/ light green
6. light green/ K
The switch itself has only 4 pins and they have 1x green/ blue, 1 x green/ white, 1 x green, and 1 green/ purple connected, but there are 2 wires (1 x green/ light green and 1 x black) unconnected. You can see all of this in the photos attached.
So what's right? Why does the wiring diagram have the extra wires but they are not used in the switch? The extra wires are clearly connected up to something else in the diagram so do those connections suddenly become unnecessary?
Giving that up for a bit I moved on to something else. I had been wire brushing and de-greasing the manifold.
I bought some high-temp paint and gave it a try. You can see the how it looks after one coat here.
Does anyone know if 800 degrees C is ok for a manifold? I was hoping to use it on the exhaust as well. How hot does that get?
Rod
Edited by rodandtom, 13 August 2015 - 07:45 PM.
