Not too much done today. I just put some last bits of filler to take out any little pin holes.
With the n/s door I put a flexible seam sealant under the lip that gets folded around the door frame. Some of that had oozed out and there was residue on the metal so today I removed all of that, rubbed it down again, etch primed and undercoated it. I think the door is ready to go back on. Any touch ups to the tack welds used to hold it on to the frame can be done with it mounted on the car.
I also undercoated some of the areas I had filled and sanded yesterday to get a seal on to it.
Next, I had a small rectangular patch to the front valence where I had cut out a rust patch months ago. That got tacked in and now I need to grind it, fill it and sand it.
Rod
Edited by rodandtom, 12 October 2014 - 04:03 PM.
