Trouble Getting Boot Hinge Pannel To Fit
rust repair
21 replies to this topic
#16 jpw1275
jpw1275
  • 2,803 posts
Posted 26 September 2014 - 12:35 PM
I must be the only one who has had no problem fitting a magnum hinge panel... went straight on with no probs but mine has the rubber on the bootlid if that makes a difference
cheers james
Yeah mine has the rubber on the boot lid also, just dont seem to push into the rubber all the way around, does yours seal up nice and every thing with no leaks.
Marcus
hi marcus..... it could be the fact i made sure i cut it before the curve on each side , but i made sure it lined up before i fully welded it in , the rubber sits fine inside the channel .... you may need to loosen the brackets on the boot lid and hinge panel then line it up and lock the boot and tighten the bolts after you have taken the rear lights out
Cheers james
cheers james
Edited by jpw1275, 26 September 2014 - 12:36 PM.
#17 marcusw
marcusw
  • 59 posts
Posted 26 September 2014 - 01:17 PM
cheers james
Marcus
Cheers james
cheers james
Hey, Yeah i tried that with the bolts etc, I think I am going to order up a new panel and try again, mine had been moved around the garage for a while and could have been bent etc,
If the new panel does not work, might get someone I know to make one haha
Marcus
#18 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 26 September 2014 - 01:26 PM
try ordering the next one from a different supplier. Although it will still be a magnum one, perhaps the supplier you used before had a bad batch?
#19 marcusw
marcusw
  • 59 posts
Posted 26 September 2014 - 04:00 PM
Yeah good point, got a guy near me who gets an order straight from magnum every week so i guess thats a safe bet
#20 bluemini17
bluemini17
  • 158 posts
Posted 26 September 2014 - 05:10 PM
Hi Marcusw
I too fitted the hinge repair panel, and like you, the fit was not so good. So as suggested I swapped for a bootlid with the rubber seal mounted to the car (not the boot lid) and the seal was much better.
Hope you solve the issue soon.
David
#21 marcusw
marcusw
  • 59 posts
Posted 26 September 2014 - 05:39 PM
Hi Marcusw
David
Nice, yeah that sill looks like a better design also
#22 Cooperman
  • 23,039 posts
Posted 26 September 2014 - 07:54 PM
Magnum pattern wing on my 850 resto project (ignore the dates, camera is not set correctly).:
Also tagged with one or more of these keywords: rust repair
