Took the nitro monster truck come buggy out earlier for a test, after sending most of Christmas replacing the clutch, flywheel, fuel tank, fuel lines and checking just about anything else, that was causing the annoying running issues I was having along with some fresh fuel.
Firstly I hate the pull start springs, as it decided to recoil back on itself. So had to swap over the pull start for a spare and have spent the best part of an hour trying to recoil up and fix it. And secondly I need to get a part of the steering remade (a new one isn't an option due to it's age) as part of the linkage is worn and has too much slop/play. Witch is affecting the handling to the point the steering is just a suggestion in the direction of travel, with it wanting to go in any direction it fancies, even if that's sideways.
